Ae111 Levin 95 BZG Lowered Springs Problem (Rattle)
Postby lost247 » Sun Mar 18, 2007 3:18 pm
Hi I have a 95 BZG Ae111 Levin Superstrut. I bought some lower springs from mag and turbo that drop it down 35mm.
The Springs rattle on ruff road. Only the rear. Its Quite wierd. the springs seem to be tight and dont move when its lowered down.
But it still makes a loud rattle on ruff road.
Is there anything i can do to fix this.
any help would be great thanks.
lost247
Postby Crampy » Sun Mar 18, 2007 4:18 pm
Might be your rear sway bar bushes are shot dude. They seem to be a common problem with these cars.
Crampy
Postby Rick » Sun Mar 18, 2007 4:23 pm
Crampy wrote:Might be your rear sway bar bushes are shot dude. They seem to be a common problem with these cars.
Grab the rear sway bar and try and move side to side (passangers side to drivers side) and if there is movement then your bushes need replacing.
Postby Ae92typeX » Sun Mar 18, 2007 4:35 pm
yeah, Id be checking swaybar bushes or bar links also
Ae92typeX
Postby Mr Revhead » Mon Mar 19, 2007 10:10 am
could be the coils of the spring smacking together
or at 35mm drop, the bottom of the car hitting things!
Postby lost247 » Mon Mar 19, 2007 9:17 pm
Yeah Thats wot it sounds like. its not dragging on the ground.
Iv thought about putting rubber hose round the spring u think dat would help.
Its a weird problem.
lost247
Postby bpimpn » Wed Mar 21, 2007 9:14 pm
yeah mine does the same thing ae . but only when im goin slow down a ruff road .
bpimpn
Postby Caveman » Wed Mar 21, 2007 9:34 pm
lost247 wrote:Yeah Thats wot it sounds like. its not dragging on the ground.
yep thats a good idea. fix a rattle on one of my cars
trd coils come with plastic on them to seperate the coils
you cut the garden hose into 20mm strips and slot about 5 or 10 on to stop the coils touching
AW11 Track Toy
Formerly known as 1998
Caveman
