What gen 3s is this?
Postby JustinSpiderholden » Wed Mar 21, 2007 4:41 pm
What Generation 3sgte do i have?
JustinSpiderholden
Postby sergei » Wed Mar 21, 2007 5:10 pm
Gen2 (ST185 or early SW20);
Best way to tell this by looking on other side of the block if your water/oil cooler is square (ST165) or round (ST185).
Postby Phothog » Wed Mar 21, 2007 6:34 pm
i'll say its a Gen 1 or 2 engine.
its not a Gen 3, they dont have TVIS ( you can clearly see the actuator)
but as Sergei has said get a picture of the other side of the block & well can easily tell.
Phothog
Postby Adydas » Wed Mar 21, 2007 7:02 pm
Id find it easyer to say its not a Gen3 as it has a 1 vs a 2 peice sump.
Adydas
Postby JustinSpiderholden » Wed Mar 21, 2007 7:58 pm
alrighty so if it's a gen 2 can someone please tell me where to bolt my engine mounts to :P
JustinSpiderholden
Postby strx7 » Wed Mar 21, 2007 8:30 pm
what are you trying to fit it to?
if its a FWD configuration, you bolt the 3 of the 4 mounts to the gearbox, the only engine mounting is just below the head on the intake side of the block, 3 bolts in a triangular configuration
Postby KinLoud » Wed Mar 21, 2007 10:28 pm
AHA - 3sgte going into a RWD setup? Am I right?
I think that the 3sgte blocks dont have all the bosses cast into the other side of the block - so you can't easily bolt rwd mounts to it?
Will the mount bolt to 2 holes and the other 2 are missing? Maybe make up a plate that will bolt to other holes on the block and weld the plate to the mount to support the block more securely.
Also - gen4 3sge (caldina, MR2, late ST20x) setup for east west don't have these bosses either from the ones I have seen. Altezza (north, south does).
Ken
Ham
021 408 863
Postby JustinSpiderholden » Thu Mar 22, 2007 1:59 pm
KinLoud wrote:AHA - 3sgte going into a RWD setup? Am I right?
Ken
Ham
021 408 863
yeah thats the problem ive got mounts ive been given mount to 2 holes perfectly but no where else, will 2 bolts be enuff to hold the motor? as for the other side the mount that i have brought will fit once i remove a bit of metal to clear the oil return for the turbo
or is there anyone on here who can help me with this?
JustinSpiderholden
