Megasquirt Tuning
Megasquirt Tuning
Postby Caveman » Wed Mar 21, 2007 6:48 pm
does anyone know the all in advance on a 4age smallport and a good all in advance with a smallport running itbs and free exhaust. Should I advance slightly more/less?
Thanks
AW11 Track Toy
Formerly known as 1998
Caveman
Postby johntramp » Wed Mar 21, 2007 10:37 pm
johntramp
Postby matt dunn » Wed Mar 21, 2007 11:26 pm
We normally set N/A race engine to 36 deg at full advance,
and ramp up from 6 or 8 at 1000rpm to max advnace at 1/2 max RPM.
thats normally on a dist setup with springs and weights,
but the theroy should be the same
Postby Caveman » Thu Mar 22, 2007 12:57 pm
ahhh yep thanks from the bit of research I did it was around 36 all in but some had strange increments, I think matts idea sounds good. Just to confirm thats 36 from 10 degrees base timing? 20 degrees at 1000rpm sounds good too 8)
edit: 20 degrees at 1000rpm meaning 10 base + 10 advance
AW11 Track Toy
Caveman
Postby matt dunn » Thu Mar 22, 2007 11:35 pm
Not sure how you are interpreting that? but
1000 rpm = 6 deg base + 0 deg Advance = 6 deg total
2000 rpm = 6 deg base + 7 deg Advance = 13 deg total
3000 rpm = 6 deg base + 15 deg Advance = 21 deg total
4000 rpm = 6 deg base + 23 deg Advance = 29 deg total
5000 rpm = 6 deg base + 30 deg Advance = 36 deg total
Something like that.
Postby Caveman » Fri Mar 23, 2007 9:58 am
Oh ok I got the 20 degrees at 1000rpm from garage dori
http://garagedori.com/forum/viewtopic.php?t=874&highlight=4age+timing
But im not running crazy compression like them
Im guessing for a smallport something like
1000 rpm = 10 base + 10 advance = 20 total
2000 rpm = 10 base + 14 advance = 24 total
3000 rpm = 10 base + 19 advance = 29 total
4000 rpm = 10 base + 23 advance = 33 total
5000 rpm = 10 base + 26 advance = 36 total
6000 rpm = 10 base + 26 advance = 36 total
7000 rpm = 10 base + 26 advance = 36 total
8000 rpm (limiter) = 10 base + 20 advance = 20 total
can you go slightly more than 36 on a 4age?
AW11 Track Toy
Caveman
Postby QikStarlie » Fri Mar 23, 2007 6:53 pm
depends on the fuel your running ? i can only get 95 octane up here. will start to detonate at anything more than 29 degress total. and less than that at lower revs of course. litstening for det with detset. stock smallport with slivertop quads, extractors, exhaust.
dout you would gain anything from going past 36. even if theres no detonation. go to far,and it'l make less power.
QikStarlie
Postby spencer » Fri Mar 23, 2007 7:18 pm
yea just sort it out as you learn to tune, Gives you alot more insight than just banging in someone elses numbers
ms63 crown
spencer
Postby matt dunn » Fri Mar 23, 2007 10:50 pm
IMO 29 at 3000 is a bit much.
Every engine is different,
If you want the most power get it done properly,
And remember, 15 Hp less is better than a buggered piston.
Postby mister2 » Fri Mar 23, 2007 10:54 pm
Dude, best way to learn is to stick it on a dyno, with appropriate knock gear. Most tuners will rent/run the dyno for you while you're tuning - it is a hell of a lot less dangerous/illegal than trying to road tune timing. Providing your fueling is ok (which is fairly easy to get right on the road) then you should only be on the dyno an hour or so which is cheap.
Then you know it is right.
Nick
www.nzefi.com
4WD Dynapack Dynamometer.
Link, MoTeC, Greddy, Power FC sales support and tuning.
Weapon of Choice: 1992 NSR250 SE
On hiatus, current location: Cambridge, UK
mister2
Postby Caveman » Sat Mar 24, 2007 9:52 am
Ahh yep thanks guys, im just looking for a bit of insight right now
Ive never tuned a motor before, thats the reason im asking the questions. Mistr2 it would be nice to dyno tune, however I dont think I can afford it... :(
After the cage is built ill be racing for a bit then hopefully installing a megasquirt and itbs, just getting info for now
thanks for all the comments, they're all really helpful 8)
I could run matt dunns figures on startup and see how that runs, if its all good then ill probably leave it as that 8) Although after talking to a few other people they recommend only about 32 degrees all in.
so...
5000 rpm = 6 deg base + 30 deg Advance = 32 deg total
6000 rpm = 6 deg base + 30 deg Advance = 32 deg total
7000 rpm = 6 deg base + 30 deg Advance = 32 deg total
8000 rpm = 6 deg base + 30 deg Advance = 30 deg total
AW11 Track Toy
Caveman
