flygt4 wrote:i found the mounts can be slightly out after being remoulded too. it should only put it out by a kunthair tho, i just had to slightly slot a couple of holes.
oh and make sure you're putting the mounts on in the right order. usually if you dont do a specific order then one wont fit
