problems from low compression? (16v 4age)
Postby l1ttle_d3vil » Thu Mar 22, 2007 11:02 pm
done a compression test on my 4age bluetop recently - #1 cylinder was about 115psi and it progressively got higher up to #4 cylinder which was about 130psi.
**engine was cold when I done the test, if it makes heaps of difference. I will redo it now the car goes and I can warm it up!**
I noticed in the ae86 service manual the compression should be in the region of 180psi, with a minimum pressure of 140 and no more than 14psi difference between all cylinders.
my engine doesnt seem to perform as good as I think it should, is this really low compression the likely cause? what sort of power loss would I expect because of this?
i've got another bluetop block + head sitting in the shed which I could chuck in if need be, assuming its better. how accurate will a compression test be by turning the engine over by hand, while its cold?
-matt
Postby strx7 » Thu Mar 22, 2007 11:16 pm
if the range only varies 15psi over the entire engine i wouldn't be too worried, things like cranking speed and engine temp alter compression readings, if you got say 100, 120, 140, 160 then i'd be starting to be concerned.
Re: problems from low compression? (16v 4age)
Postby matt dunn » Thu Mar 22, 2007 11:19 pm
l1ttle_d3vil wrote: how accurate will a compression test be by turning the engine over by hand, while its cold?
About as accurate as measuring it by holding your finger in the spark plug hole and guessing the pressure.
Postby big_boy » Thu Mar 22, 2007 11:30 pm
do a hot test & then drop about 10 drops of oil down each cyclender & do it again & see what all thoes readings are
then you will know were you stand
for sale EE90
big_boy
Postby strx7 » Thu Mar 22, 2007 11:46 pm
If an engine has those plug leads which have gromets where they go thru the rocker cover, you can do a crude compression test by simply taking the plugs out and one by one cranking it over and seeing how high the plug lead gets launched. Highly Crude but highly effective, cause if one doesn't get launched you know its got naff all compression on that cylinder.
Postby matt dunn » Fri Mar 23, 2007 12:00 am
Yes but what about this bit?
l1ttle_d3vil wrote: by turning the engine over by hand
Postby strx7 » Fri Mar 23, 2007 12:09 am
I've never seen the size of his arm muscles so can't comment :P
Postby l1ttle_d3vil » Fri Mar 23, 2007 9:22 am
:lol: so is there any way to accurately check the compression while the engine is out of the car?
will try putting oil down the spark plug wholes tonight and see what the results are.
Postby thaphatty » Fri Mar 23, 2007 9:29 am
grab starter, and bellhousing + flywheel, 12v to starter
thaphatty
Postby l1ttle_d3vil » Sun Mar 25, 2007 2:05 pm
finally got a chance to do a proper compression test on my engine.
warmed it right up and all 4 cylinders were about 195psi - 205psi.
that was with the accellerator fully open too, with it close it was around 150psi.
so looks to be all good...guess i'll have to put a turbo on to get more power :roll: what a shame... :lol:
