random oil leak after oil change... caldina gtt
Postby embai883 » Fri Mar 23, 2007 10:59 pm
hey guys... need little help here...
i just did an oil and fiter change myself today for my caldina gtt
after that it had some leak on it... it seem to leak to the plastic cover under. the location is between the sump and the filter... i check the sump plug, it is dry, check the filter as well, dry...
the car had only travel 57000km... before the oil change everything was good and tight... and now this... :(
can anyone shed some light pls....
could it be engine oil problem? i am using castrol edge sport 5w - 30... fully synthetic.
the new oil filter that i had use was the original toyota filter. unlike the one that i pull out which was FRAM...
any help is really appreciated...
embai883
Postby embai883 » Fri Mar 23, 2007 11:34 pm
those who is knowledgeable in gtt pls help.... :(
embai883
Postby Brick » Fri Mar 23, 2007 11:36 pm
besides the oil filter and the sump plug was there anything else you removed?
Brick
I know Kung Fu
Postby Santa'sBoostinSleigh » Fri Mar 23, 2007 11:46 pm
obvious things to check:
you didnt spill oil all over the engine when refilling
sump plug is done up tight enough and isnt cross threaded
you used the right part number oil filter (4AGE/3SGTE are the same)
the oil filter is done up tight and isnt cross threaded
and as brick said, did you fiddle with anything else?
ive never had any problems changing my caldina filter
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby embai883 » Fri Mar 23, 2007 11:59 pm
hmmm... cross threaded... dont think i am strong enough to cross threaded... i havent removed anything else... apart from the filter and sump plug
the last time i check it the sump was dry and the filter too... the plastic cover near the filter and sump was a little wet...
the oil filter i use this is the part number 90915 - 10004 this is compatible with all 3sgte apart from st165?
my old st185 use this as well... caldina had a different one?
is it possible that the oil drip when i was trying to remove the filter on to the plastic cover?
embai883
Postby Brick » Sat Mar 24, 2007 12:08 am
yes its possible
Brick
I know Kung Fu
Postby solitaire » Sat Mar 24, 2007 2:16 am
unless you angle the car in a way that the oil will drain out of the filter your almost guranteed to spill oil out of the filter,
Did you put a small film of fresh oil on the filter rubber seal when you put it on?
Once the filter rubber seal made contact with the engine block you should of turned it no further than another 3/4 revolution.
AE92, KZJ120, KDJ120
solitaire
Postby 85AW20v » Sat Mar 24, 2007 5:44 am
Also make sure that the seal off the old filter isn't still stuc to the block as you will get a leak from between the old seal and the new one.
See ya
Simon
85 MR2 20v
85AW20v
Postby bluemaumau » Sat Mar 24, 2007 11:06 am
yes you need to clean both surfaces.
filter and sump
im not sure about 3s's but i know 4ages use a sump crush washer between the sump plug and sump.
its made of a cardboard i think and you are uspposed to replace it with each oil change, as they get $&#$% after being crushed.
repco and stuff dont sell em, so youll need to go to toyota
Postby snwtoy » Sat Mar 24, 2007 11:13 am
I usually remove the plastic cover - it's only abotut 10 small screws, and makes the job so much cleaner and easier. Just make special note of the couple of screws that tap into metal and not plastic.
Definitely check this cover for oil, as it has grooves in it which oil will sit in.
snwtoy
Postby embai883 » Sat Mar 24, 2007 12:59 pm
i did replace the washer as well between the sump and the plug...
i check this morning it seems to be fine now... maybe it is like what snwtoy said... the oil sits in it.. should have remove the plastic cover :D
embai883
Postby TRD_ZERO » Sun Mar 25, 2007 11:16 am
Simon85MR220v wrote:Also make sure that the seal off the old filter isn't still stuc to the block as you will get a leak from between the old seal and the new one.
Yip i learnt that the hard way it wasnt pretty :oops:
TRD_ZERO
Postby RS13 » Sun Mar 25, 2007 12:24 pm
When you take an oil filter off, its' damn near impossible to not spill used oil from the filter down the side of the block, unless you're a ninja and can spin the filter off the thread in less than a second! I always degrease the engine after an oil change anyway, I can't stand the smell of burning oil, or oil all over the bottom engine bay cover.
RS13
