Quick Flywheel Question
Postby TRD_ZERO » Sat Mar 24, 2007 10:27 am
Im putting a e51 box onto a blacktop at a later stage and want to know if i can use my blacktop flywheel. Im not worried about clutches im asking if the blacktop flywheel will work with the e51 box or are the outer diameters bigger between the blacktop ones and gtz ones.
TRD_ZERO
Postby thegreatestben » Sat Mar 24, 2007 10:33 am
Blacktop flywheels are smaller than GZE ones so you won't have any problems fitting it in the box
thegreatestben
Postby TRD_ZERO » Sat Mar 24, 2007 10:36 am
So the starter motor will engage it no problem? Im just worried that it would be too small and the starter motor wont turn it.
TRD_ZERO
