Engine Bay prep
Engine Bay prep
Postby deaf_rattle » Sat Mar 24, 2007 6:57 pm
I am currently prepping my engine bay for painting.
Ill probably go the whole nine yards and remove the brake booster and lines and then paint the whole bay like that.
There is some oil and dirt and stuff that im having a hard time removing.
Can anyone recommend a decent spray on cleaner for that sort of thing?
im chewing through cans of degreaser at the moment.
Also, is there anything else one should do while they have the engine bay in this state?
Ill probably remove the air con fittings and have a plate welded in, just to make it look abit smoother.
Postby bluemaumau » Sat Mar 24, 2007 6:58 pm
i just water blasted the thing down. worked mint
Postby Lloyd » Sat Mar 24, 2007 7:05 pm
Get some paint/rust removing discs from Mitre 10/other hardware place. 3M make them, was another brand too. Will do exactly what you're after
Postby Infinite » Sat Mar 24, 2007 7:42 pm
wax and grease remover from repco rips oil and grease right off use it for cleaning everything at work it that didnt move it acitone just dont get that on good paint lol
Lots
Infinite
Postby the fallen303 » Sat Mar 24, 2007 8:31 pm
hey matt, if you can, find a grommet possibly from a mk2 that didn't have a/c to block the hole through the firewall, as that way if you need to get wiring say from stereo, or maybe sensor for guages, etc, you have a tidy and easily accessible way through the wall, but will still look tidy enough if you don't run anything through it.
true house of JZ
Stay true to the origin
the fallen303
Postby deaf_rattle » Sat Mar 24, 2007 10:28 pm
the fallen303 wrote:hey matt, if you can, find a grommet possibly from a mk2 that didn't have a/c to block the hole through the firewall, as that way if you need to get wiring say from stereo, or maybe sensor for guages, etc, you have a tidy and easily accessible way through the wall, but will still look tidy enough if you don't run anything through it.
good thinking. i hadnt thought of that. would be the easiest option.
i wonder if they come out with no a/c as an option
Postby evil_si » Sat Mar 24, 2007 10:56 pm
i just use scotch brite to prep engine bays, and prep sol does wonders as well
evil_si
Postby frost » Sun Mar 25, 2007 4:37 am
aussie export. spray on de-greaser. the best thing to come out of oz for $2.99 a bottle. i buy it by the box ful.
just spray it on and wait 5 min and spay on some more and 5 minutes later hose off. use the whole bottle if u must, for $3 a bottle its cheap from supacheapauto.
Postby bluemaumau » Sun Mar 25, 2007 12:51 pm
yea that stuff is good, i bought 10 for 20 dollars a month or so ago
Postby tsoob » Sun Mar 25, 2007 10:16 pm
yeah use prepsol (w&g) remover and scotch brite or simalar, i used these microfibre cloths they work really good to get grease off then sand it back what kind of paint u using ?
tsoob
Postby Malcolm » Tue Mar 27, 2007 2:19 am
if you have any questions about prep/painting then feel free to flick me an email or text or call me. I used to just use some strong detergent type degreaser to do the initial clean, then go over it with wax and grease remover before sanding. Sand with scotch brite or similar to remove the gloss from the factory finish, and you can top coat straight on top of that.
Postby RED TOP MR 2 » Tue Mar 27, 2007 6:06 pm
you now get 100ml free with that australian export degreaser.yeah
RED TOP MR 2
