Boring bluetop rods to take 20mm gudgeon
Postby Volodkovich » Mon Mar 26, 2007 6:00 pm
I've heard a few people talk about this, and would quite like to do it to the 4age i am building up soon.
So basically i can run the lighter crank/rods with the later pistons.
Are the bluetop rods still strong after being bored to take the 20mm gudgeon pin? It will be a mild tune n/a 16v, in a road going club car. So will get thrashed but will be looked after.
Would like to hear peoples opinion on this.
Volodkovich
Postby Volodkovich » Wed Mar 28, 2007 12:56 am
Anyone?
Volodkovich
Postby thaphatty » Wed Mar 28, 2007 9:56 am
Id be very interested in this also, simply for the fitting of later model pistons.
I've killed a few 4ags, and its never been because the gudgeon hole wasnt strong enough, always been oil starvation.
thaphatty
Postby Mr Revhead » Wed Mar 28, 2007 12:33 pm
i know someone doing this
and iv heard of it being done
been a while since iv looked at a blue top rod but i seem to recall theres no problem at all
Postby Distrb » Wed Mar 28, 2007 12:36 pm
Mr Revhead wrote:i know someone doing this
According to said person, the just machine out the bush, and run with none. Doesnt alter the strength of the rod.
Distrb
Regular Poster
Postby levinguy » Wed Mar 28, 2007 1:27 pm
has been done on the block i just brought,
the guy who built the block seemed to think it would be fine
levinguy
Postby Volodkovich » Fri Apr 13, 2007 9:05 pm
So i assume you make the gudgeon press fit into the rod if you dont run a bush in the little end?
This way the piston would rotate on the gudgeon rather than the gudgeon rotating in the rod.
Volodkovich
