crossflow 4k???
crossflow 4k???
Postby 79rolla » Fri Mar 30, 2007 10:01 pm
im just ondering if there is a crossflow heaid that would fit onto my 4k without any major problems and if it would be worth the effort preferibly from a smaller engin so i can increese compretion while im at it
iv been thinking about this for a while now so any ideas woud be good
thnx
(sorry bout spelling :oops: )
past: AE82 FXGT
79rolla
Postby Lloyd » Fri Mar 30, 2007 10:19 pm
Not that you can find/afford
Postby fangsport » Fri Mar 30, 2007 10:20 pm
buy a 2t-b.
take 0.060" off the head.
1600cc of hi-comp crossflow pushrod goodness :wink:
fangsport
Postby Volodkovich » Sat Mar 31, 2007 1:32 am
fangsport, how well do 2t-b's go with high compression?
Just got a engineless te71 and thinking of putting one in to get it running while i build my 4age
Volodkovich
Postby fangsport » Sat Mar 31, 2007 10:42 am
Volodkovich wrote:fangsport, how well do 2t-b's go with high compression?
really well. the 2-tb has a higher compression ratio than the 2tc and 3tc, so when you fit a 60thou head onto it , it gets bumped up even further. kept the 4ag powered cars honest for a season.
fangsport
Postby Volodkovich » Sat Mar 31, 2007 1:32 pm
sounds awesome. Any other tricks you did to the motor?
Volodkovich
Postby fangsport » Sat Mar 31, 2007 1:54 pm
Volodkovich wrote:sounds awesome. Any other tricks you did to the motor?
really old rally ground cam, flows 32/36 weber.
fangsport
