i think i will stick with the toyota thanks!strx7 wrote:if the kit car deserves some real cash spent in the engine bay, there aint no substitute for a 40V 4.2 Quattro V8, the power delivery of those engines is something others can only aspire to.
thanks for that.....i will be in touch!nite b wrote:A well thought mild turbo setup on 1UZ will give you the HP you are looking for. If you get stuck, give us a buzz here:
http://1uzquadcam.co.nz
Good luck
Mr.Phreak wrote:The 1UZ (4.0L) is alloy, The 2UZ (4.7L) is iron, the 3UZ (4.3L) is alloy
The 1UZ will be cheap, the others won't
hmmmmm ok...sounds like the VVT 1UZ is the way for me to go........is there any particular markings or codes on the engine that i should look for when i go to buy one so i can tell its a genuine?fivebob wrote:There are several versions of the 1UZ, later models are better designed and incorporate quite a few changes but are much harder to find. Not sure about any other versions but the Lexus LS400 underwent 1 minor revision in '92/93 (change to injectors/ injection system) and two major revisions;
'95 had changes to the heads, block, Increased compression, More duration o nthe inlet camchanges to the injection system, ECU, and MAF Sensor, this increased power from 186kw@5600rpm to 194kw@5300rpm and torque from 353Nm@4400rpm to 366Nm@4500rpm.
'98 had VVTi along with more changes to the head (upright intake port, taper squish, bigger valves, underbucket shims, more duration on the inlet cam(VVTi), steel head gasket, improved block and crankshaft rigidity, changes to the piston skirt, piston coated with friction modifier, ACIS, returnless fuel system, DIS direct ignition system, and increased thermostat size. Power 216kw@6000rpm, Torque 407Nm@4000rpm.
I have full documentation on all the differences between the LS400 versions of the 1UZ as well as the differences in the 3UZ, I'll load it up to my web server if anyone wants to see it.
