tick tick sound, but not VVT
Postby BZR4AGE » Sat Mar 31, 2007 2:36 pm
hi there guys, was going through a burgerking drive through when i noticed the sound. then i went home and checked it out.
The engine is making a tick tick sound, specifically on the head. and is not VVT because i have camshafts and adjustable cam pulleys in there, so can't be VVT. What could it be, will take it to a mechanic during the week.
Just want some "pre-money-spending on repair" advices
BZR4AGE
Postby Mr Revhead » Sat Mar 31, 2007 2:40 pm
are you sure its not the normal injector noise?
Postby BZR4AGE » Sat Mar 31, 2007 2:42 pm
hi there revhead. pretty sure i never heard that sound before, just came up today, only noticeable when i have all my windows up and idling.
BZR4AGE
Postby l1ttle_d3vil » Sat Mar 31, 2007 2:54 pm
easiest time to hear the injetors is when its idling. pop the bonnet and just lift the revs real slowly (easiest to do it by hand in the engine bay) and see if the "ticking" you can hear speeds up.
at higher revs it stops ticking as the injectors are constantly open (i presume) :roll: then as the revs drop again they'll start ticking...
Postby BZR4AGE » Sat Mar 31, 2007 3:01 pm
hi little devil. I just did that, and yes, is exactly what you said. The sound is coming from between the throttle bodies and injectors.
How come I never heard these before, is it a big issue? are my injectors on the way out?
Sorry for these questions aye, I am still a newbie to these stuff. Cheers
BZR4AGE
Postby sergei » Sat Mar 31, 2007 3:22 pm
loud injector is healthy injector ;).
btw if the ticking wills top after you have shut off throttle after revving it over 2000rpm, that will be definitely injectors.
Postby flygt4 » Sat Mar 31, 2007 3:42 pm
most likely its been there forever , you probly only just noticed it :lol:
mine are loud as hell, had me scratching my head after i put larger injectors in and got louder :wink:
flygt4
Postby frost » Sat Mar 31, 2007 5:54 pm
relay under the hood going nuts? haha i love ticking
Postby Cakky » Sat Mar 31, 2007 6:08 pm
mine are loud as well
i assume its the injector or tappets?
dunno lol
1989 Corolla GT sedan blacktop 20v
Cakky
Postby l1ttle_d3vil » Sun Apr 01, 2007 1:02 pm
BZR4AGE wrote:How come I never heard these before, is it a big issue? are my injectors on the way out?
ive got decent injectors in my car and can hear them ticking easily over the engine, with the doors/windows all shut in the car.
