oil pressure sender
oil pressure sender
Postby vvtirep » Sat Mar 31, 2007 3:50 pm
hey guy wonder if you can help me.
i have a 1995 levin bzg and have an oil pressure guage and the oil pressure sender does not fit straight into the block. i have therfor had to put two spacers in so it can fit. the only problem is that this vibabrates and the thread in the block snaps because brass is a very soft metal. this is the 2nd time it has happened and so i lose all my oil.
has anyone else had this problem and how did you go about it?
im thnkn of just ditchn the oil presure guage and block up the sump in the pump because it just cost me money everytime it breaks off.
any suggestions would be great. thanks
Tim Taylor
vvtirep
Postby Ae92typeX » Sat Mar 31, 2007 4:11 pm
get a non-brass thread, or, make a support mount up for sender so vibration aint an issue perhaps(depending whats around for it to bolt to)
Ae92typeX
Postby frost » Sat Mar 31, 2007 5:51 pm
where do you get non brass ones from? ive only come across brass and copper ones. i'm interested too. i tried all auto shops and even gas places and plumbing supply shops,
Postby no_8wire » Sat Mar 31, 2007 6:07 pm
Brassfit.co.nz
They have stainless steel oil fittings...
no_8wire
Postby 92mr2paddy » Sun Apr 01, 2007 1:28 pm
yea, simply make a bracket with a clamp that holds sender in its place, therefore it can rattle and shake all it wants to :)
92mr2paddy
Postby matt dunn » Tue Apr 03, 2007 12:40 am
get a piece of flexible braided line and run it from the block to the sender and mount the sender on the inner guard.
