inlet gaskets? - sealant
Postby bluemaumau » Sat Mar 31, 2007 8:28 pm
alrighty, in the hope of fixing the high idle the corolla is suffering from i removed the whole intake on tuesday.
some of the standard gaskets (inlet and outlet pipes on s/c) were pretty buggered, so i took em off and applied a healthey dose of toyota black sealant (the stuff used on sumps).
and once the car got warm it started making some sickly anti-lag noises.
just wondering if the sealant could have melted, or if its the good stuff?
will
Postby l1ttle_d3vil » Sun Apr 01, 2007 1:01 pm
never heard of that stuff being used on the inlet manifold, i just use brand new gaskets. have you checked your timing with a good timing light? that can effect your idle quite a bit...
Postby bluemaumau » Mon Apr 02, 2007 12:35 am
yea i have its idling mint (1200rpm) at 10ATDC. lol
