navara diff?
navara diff?
Postby NOLAW » Sun Apr 01, 2007 9:56 am
how strong are these compared to the hilux diffs and are they good to use for conversions like the hilux diff?
NOLAW
Postby evil_si » Sun Apr 01, 2007 11:00 am
i'm not to sure how strong they are but if you want to put one in a car you will either have to run six stud rims or convert the diff to five stud as all navaras are six stud whereas 2wd hilux are five stud.
evil_si
Postby NOLAW » Sun Apr 01, 2007 11:27 am
oh true so theres no 5 stud models? oh wel flag that idea :lol: cheers man
NOLAW
Postby evil_si » Sun Apr 01, 2007 12:50 pm
lol, nope all 6 stud, im converting my navara to hilux rear axle.
evil_si
Postby NOLAW » Sun Apr 01, 2007 5:43 pm
cheers man, hae by the way that motor i bought off you, if you can remember. was the flywheel that came with it off a AE92 or AE101?
NOLAW
Postby Zak » Sun Apr 01, 2007 6:58 pm
measure the clutch plate surface, 200mm will be ae92 and 212mm will be ae101
Zak
Postby l1ttle_d3vil » Sun Apr 01, 2007 7:24 pm
[quote="evil_si"]i'm not to sure how strong they are but if you want to put one in a car you will either have to run six stud rims or convert the diff to five stud/quote]
can you do that? thought you could increase the number of studs, but you weren't allowed to change say a 5 stud diff to 4 stud...
Postby strx7 » Mon Apr 02, 2007 7:56 am
Navara diffs are generally borg warner style Banjo set ups unlike a hilux
Postby fangsport » Mon Apr 02, 2007 4:41 pm
strx7 wrote:Navara diffs are generally borg warner style Banjo set ups unlike a hilux
unless you get the early one which is similar to the Caravan/720 diff. H190 do have good spread of ratios, which is part of the reason why i am going to use one.
the diesil C20/22 diff is another option, H190 and four stud(4 x 114.3) and is the diff i am using.
fangsport
Postby strx7 » Mon Apr 02, 2007 5:40 pm
E24 Caravan diffs are banjo and a known for wearing out the bearings
Postby fangsport » Mon Apr 02, 2007 5:46 pm
strx7 wrote:E24 Caravan diffs are banjo and a known for wearing out the bearings
ok, what the intermediate van then?? Homy, maybe??
fangsport
Postby strx7 » Mon Apr 02, 2007 7:18 pm
Homy's & Caravans are the same thing. Urvan maybe?
Users browsing this forum: Bing [Bot] and 4 guests
