How to: Digital speedo signal, to analogue dash?
Postby RomanV » Sun Apr 01, 2007 9:18 pm
Okay, well I want to keep my standard dash unit, which runs a speedo cable... but I've got an 'electric' speedo drive for the gearbox.
What's the best way to get it working? Use an electric motor to spin the back of the speedo drive where the cable goes, using the signal from the gbox as a reference via some circuitry?
Or is there any easier way? :)
Any advice/etc appreciated!
Postby sergei » Sun Apr 01, 2007 11:51 pm
just use the mechanical unit instead of electronic sensor. You need to find one from same series gearbox.
Unless you are using an oddball gearbox, it will be easy to find right sender.
Are you using altezza gearbox?
Postby RomanV » Mon Apr 02, 2007 1:24 am
Yep, altezza six speed, which IIRC is made by 'aisn' as opposed to toyota.
I doubt that it comes with a mechanical sender though?
What do you think the odds are of finding one that would fit. Not great I'd imagine.
Postby bluemaumau » Mon Apr 02, 2007 11:44 am
post i picture up with a rular next to it someone may know of a similar unit
Postby sergei » Mon Apr 02, 2007 3:17 pm
you can actually modify electronic one into mechanical, with some machining/drilling and borrowing bits from a donor mechanical unit.
Postby KinLoud » Mon Apr 02, 2007 8:30 pm
Hi Dave,
There are lots of toyotas with electronic speedos (togs, togs, togs, undies).
I (now) have another spare AA60 speedo with revcounter. I'm sure that it is possible to put an electronic speedo into the AA60 dash... might be a bit fiddly but entirely possible. I've done (sort of) similar stuff with mixing and matching dash parts in the past.
Look here... I can see an altezza radiator in the pichttp://www.trademe.co.nz/Trade-Me-Mo ... 152867.htm
Ken
Ham
021 408 863
Users browsing this forum: Google [Bot] and 20 guests
