C52 + 4AGZE clutch choice
Postby The_Lorax » Tue Apr 03, 2007 8:37 am
Good Morning,
I'm planning to bolt my C52 LSD gearbox & blacktop flywheel to the 4agze in my AW11 instead of using the E51 gearbox.
Will a Toyota OEM blacktop clutch be up to the job, or should I go aftermarket? What type of clutch are you 20v turbo guys running? At the end of the day i'd prefer to blow a clutch instead of breaking the gearbox or shearing off driveshafts.
Cheers,
Tim
The_Lorax
Postby thegreatestben » Tue Apr 03, 2007 9:16 am
Use a standard blacktop clutch, Only $180 through warwick for a complete kit.
thegreatestben
Postby Mr Revhead » Tue Apr 03, 2007 11:34 am
depends how u drive it
my one had a stock clutch, but as the previous owner used it for drag racing it didnt last
so he used a brass puck clutch
which i strongly recomend NOT using for a daily driven car in wellington!
TRD one would be my choice
