weird caldina gtt noise....
Postby embai883 » Sat Apr 07, 2007 11:11 pm
hi guys,
i have this weird random noise on my gtt recently, it is like a high pitched and whinning noise when the car is in neutral, it goes away when clutch is depress,it sounds like it came from the transmission area... throw out bearing going out ??? or gearbox problem..., i try observe for a few more days...
the car had only travelled 58000km and i assume that shouldnt happen, this also sort of happen on my old gt-four st185 but doesnt affect anything though still engage properly and stuff....
or izzit i sux in driving manual :D
are these common???? those with the knowledge pls help
embai883
Postby Mr Revhead » Sun Apr 08, 2007 1:09 am
yeah sounds like thrust bearing
Postby Lloyd » Sun Apr 08, 2007 11:27 am
Does it do it when in gear and driving along? Release bearing noise is usually with clutch pushed in and goes away when you release it
Postby sergei » Sun Apr 08, 2007 6:41 pm
Try moving release fork with hands and see if that changes the noise.
If release bearing is semi-seized it will grind against pressure plate making bleeding ears noise even if you are not really pressing it.
Postby Ae92typeX » Sun Apr 08, 2007 10:28 pm
so it goes away when you push the clutch in yes?
Could be input bearing on its way out. Dont know what those boxes are like, but have changed on a few cars of similar mileage.
If its when you push clutch in then release bearing as above.
Ae92typeX
Postby embai883 » Wed Apr 11, 2007 1:06 pm
hmmm... input shaft bearing... hope it is not something very bad cause the sound is not present anymore.... :?:
embai883
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
