ae85 conversion - clutch/gearbox issue
Postby nic32 » Tue Apr 10, 2007 12:46 am
Hey hey
I've almost finished an ae82 blue top in to an ae85. All hasn't gone well, have fixed most issues, however have a fairly major one.
I'm running a k50, with the 3a/k50 plate(lots of meat but not the nicest looking) and the 4age cover and flywheel(spigot bearing installed)
I can select a gear with the clutch in or out, ie there is no drive getting to the gearbox. I've tried mucking around with the cable adjustment at the top(the circlip at the top) - while this gives a good pedal it still doesn't change the situation.
I read in the faq that ae85coupe provided that I may have to run a spacer behind the release bearing, but I'm not sure that would fix the situation.
Help please
chur chur
**edit** if I do need a spacer, can I get one from somewhere, or if it needs to be made, what dimensions and what material?
nic32
Postby rwd_mayhem » Tue Apr 10, 2007 12:05 pm
so the engine is running and you can just put it into gear and nothing happens? id check the fork and release bearing. it should work without a spacer.
current: 1975 Valiant Regel
previous: 1980 mazda 626, 4AGE AE70 sedan, AE70 sedan, mk2 escort, KP60 starlet, TE71 liftback X2
rwd_mayhem
Postby neo » Tue Apr 10, 2007 1:14 pm
<cough> its never going to leave the drive way <cough>
<cough> just like the charade <cough>
neo
Postby nic32 » Wed Apr 11, 2007 10:35 am
<cough> hits neo upside the head <cough> thinks to himself why did he cough while hitting someone....
So Mr Mayhem, you think that the clutch is staying engaged? What would cause that? Sounds like it's box off again....
Could it also be the plate slipping really bad? I would have thought I'd get some sort of movement though.
nic32
Postby rwd_mayhem » Wed Apr 11, 2007 11:05 am
nic32 wrote:<cough> hits neo upside the head <cough> thinks to himself why did he cough while hitting someone....
it sounds like the clutch isnt engaging at all if it doesnt stall when in gear and car running. is the clutch plate definatly the right way round?
well you said it has plently of meat on the plate so its not slipping, im using the exact same setup as you so the parts are right and sorry but yea i think the only way to sort it out is to take it off and check everything again, but hey thats not too hard.
rwd_mayhem
Users browsing this forum: Bing [Bot] and 2 guests
