Silvertop 20v Mods
Silvertop 20v Mods
Postby MINTFX » Tue Apr 10, 2007 5:22 pm
Ive searched on these forums but cant seem to find much information (I hate how it searches and brings up almost every thread)
Current mods:
Battery in Boot, Cold air box up front.
Cat back exhaust
The rest is pretty much standard. Im not really looking at doing anything serious, but what is something thatll give me a little bit more go? Maybe up to $500. If there are any other threads like this would someone please kindly point me to them :D
MINTFX
Postby Mr. Mainstream » Tue Apr 10, 2007 5:24 pm
good tune. oil,filter,sparks,Phat leads.
Maybe roll into kelford or get sum extractors. but dont expect much from your 1.6
75 MK2 Ford Escort L 2.1L
Various Others
Mr. Mainstream
Postby Bling » Tue Apr 10, 2007 5:27 pm
get yourself a set of blacktop extractors is one thing you can do cheap
Postby AceSniper » Tue Apr 10, 2007 5:53 pm
TRD heady $96ish skim the head (clean it all up while there)
check timming
oil/plugs
pull weight out of car
blacktop 4-2's
AceSniper
Postby MINTFX » Tue Apr 10, 2007 6:03 pm
Do the blacktop 4-2s bolt straight up?
MINTFX
Postby AceSniper » Tue Apr 10, 2007 6:17 pm
yeap
AceSniper
Postby RedMist » Tue Apr 10, 2007 6:25 pm
AceSniper wrote:TRD heady $96ish skim the head (clean it all up while there)
Do you actually get an increase in power from an increase in silvertop compression? I would have thought the only thing you did would have been to detonate it to hell... or have to wind back the timing.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby AE82 FXGT » Tue Apr 10, 2007 7:22 pm
I'd be on the lookout for a sard or mines plug and play ecu, even if you move onto something more serious (link etc) those ecus seem to hold good value.
AE82 FXGT
Postby Loudtoy » Tue Apr 10, 2007 7:59 pm
Take everything out that you don't need, that way it'l have way more go, stop faster and corner better as well. Also if you decide to put everything that you pull out back in it later it's really easy to get everything super clean :)
101 facelift standard = 1060kg's
101 facelift loudtoy style weight reduction = 906kg's
Now thats a noticeable difference when you are driving :) and good for about 2 10ths in a straight line and 2 seconds around taupo old track :)
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby Flannelman » Tue Apr 10, 2007 8:49 pm
just did the Blacktop extractors on my Silvertop. The new ones have FGK on them, asuming brand but got no info on them. got from local wreakers.
Anyway, went to meremere.
Fastest before mod was 16.167 sec @ 139km/h.
Fastest at end of day was 15.881 @ 89mp/h so think its 146km/h (bastards changed timing system!!) all day (even at slowest of 17 sec, screwed up launch twice) still managed 88Mph.
FWIF Final speed on 1/4 mile is a measue of horsepower.
Oh and traveled up from taranaki (at pace) 3min 38 over Mt messenger...
raced and got back to te kuiti. 529km on 46L of gas.
Economy with preformance increase, so double bonus.
Flannelman
formerly known as Affroman
Postby Mr Revhead » Tue Apr 10, 2007 8:51 pm
ensure u have facelift ITBs.
SARD or aftermarket ecu
run on the best fuel you can
fit catch can that to BOTH rocker cover pipes, do not use feed back system.
check leads (specificly the coil lead)
as stated 2-1 section
fit k&n panel to stock airbox
ducting to stock airbox
blacktop extractors
Postby strap-on » Tue Apr 10, 2007 8:59 pm
makes me want another silvertop :(
strap-on
Postby MINTFX » Tue Apr 10, 2007 9:09 pm
Mr Revhead wrote:ensure u have facelift ITBs.
blacktop extractors
ITBs?
How much is an aftermarket ecu?
Im running it on 98 :)
I might invest in that
Ive already spent the money on making the cold air pipes(plus it sounds awesome)
MINTFX
Postby RedMist » Tue Apr 10, 2007 9:39 pm
Hes talking about the facelift TB manifold.. not the TB's themselves. The facelift manifold is more of a teardrop shape rather than the oval and slot design of the pre facelift manifold.
There is a groupbuy on Links... or there was... in the parts buy sell section.
Spent the money on cold air pipes? You havent removed the stock airbox have you?? BiIiiig no no. You will get considerably less power by doing so. Unless you make up a custom airbox and straight pipes, but then you'll probably be well and truly through the firewall in order to get the Helmholtz frequencies correct.
Revhead is talking about a cold air box in order to feed cool air into a pod filter.
RedMist
Postby MINTFX » Tue Apr 10, 2007 10:24 pm
Ahok. I meant ive gotten rid of the rubber pipes and pipe straight aluminium ones in place (looks nicer aswell). I plan on isolating the pod filer with a cold air box i will make from heat shield and make sure it has plenty of air getting to it. I did a quick search and someone on a corolla forum said the a Sard ECU gives a 12% hp increase.
MINTFX
Postby Mr Revhead » Tue Apr 10, 2007 10:37 pm
no, im talking about keeping the stock airbox and putting a k&n panel filter into and running a pipe to that :P
yeah the guy who said 12% really knows his stuff, hes a god, hang off his every word :lol:
what forum was that?
Postby MINTFX » Wed Apr 11, 2007 10:42 am
Im not saying im going to run out and get one, so dont jump to that conclusion. Rolla Forums or something like that.
MINTFX
Postby Mr Revhead » Wed Apr 11, 2007 10:49 am
rollaclub?
hehehe ill let you in on it.... it was me who dyno tested on at 12% gain :P
cant gaurantee that every one will do that, as they may have been tuned for specific cars
Postby MINTFX » Wed Apr 11, 2007 10:56 am
Ahok. Just out of curiosity how much is a Sard or similar ECU?
MINTFX
Postby Mr Revhead » Wed Apr 11, 2007 11:02 am
you have to find one first
i got mine for $250. last one i saw sold for like $900. which imo is a bit much as for a few hundy more you have a link.
