Anyone know what box this is?
Postby Lloyd » Sun Apr 15, 2007 6:45 pm
No idea what it came out of other than it may be a Hilux of some description. Spline on the output shaft is the same as the W57 I had, though there are some slight differences on the outside and I didn't pull bellhousings off to check if they are interchangable or not. Strange that shifter is so far forward on this?
Postby postfach » Sun Apr 15, 2007 7:54 pm
i dont think its a W series, they have 6 bolts holding the shifter bit on and that box only has 4
postfach
Postby z|gen » Sun Apr 15, 2007 8:00 pm
definatly looks like a G series box out of a 2wd hilux..
AE91 SUPERCHARGED COROLLA
z|gen
Postby 2LTR Rona » Sun Apr 15, 2007 8:02 pm
since we are on the guess the box game...anyone got a clue on this one ?
http://www.villagephotos.com/pubbrowse. ... id=1462154
2002 Altezza, 1974 KE25
2LTR Rona
Postby postfach » Sun Apr 15, 2007 8:26 pm
2LTR Rona wrote:since we are on the guess the box game...anyone got a clue on this one ?
that's a W5x box, 6 bolts around shifter, steel sandwich plate (its got rust), right number of ribs on each side, shape and size
compare it with this one:
postfach
Re: Anyone know what box this is?
Postby Jason T » Sun Apr 15, 2007 9:05 pm
[quote="HRT"]No idea what it came out of other than it may be a Hilux of some description. Spline on the output shaft is the same as the W57 I had, though there are some slight differences on the outside and I didn't pull bellhousings off to check if they are interchangable or not. Strange that shifter is so far forward on this?
Just another version of the W series found in utes etc
That has a L series diesel bell
I have two at work 1 from a 5K liteace noah and 1 from a 3S noah look the same as this with mount on top as well as under
This box type was what went into the import x ae86
Any W series bellhousing bolts on with out issue
Fixing Toyota's since '87
Jason T
Users browsing this forum: Bing [Bot], Google [Bot] and 5 guests
