AE101 4A-GZE Air Intake Options
Postby DECEVR » Sun Apr 15, 2007 11:00 pm
Greetings,
Just aquired a new 1991 Levin GTZ-R i think it says on the side of it...
Anyway, Previous owner did some interesting modifications, including a blowoff valve he could never make work... funny that (I didnt bother explaining it, he didnt look like he'd understand)
So on a side note, if anyone wants a Type-1 Bov (Racepro?) its up for grabs.
Secondly, hes put a Pod Filter on it, its in the worst place i can imagine, not only is it getting lovley hot air from the engine, its also right behind the radiator fan so it gets blasted with hot air while moving!
Due to that, boxing may not be the best option, unless i shift the battery, and relocate the filter to behind the light as in 'normal' cars.
But before i start mucking about, what is generally done in this area? and can i perhaps have some pics of what others have done, or suggest. I have a pulley kit otw and plan on sorting this and then beefing up the fueling with some MR2 injectors and a larger fuel pump (i figure a good search will give me all the info i need on this)
DECEVR
Postby AE82 FXGT » Sun Apr 15, 2007 11:10 pm
I haven't done yet, but I plan to make an air box to just fit over a pod and duct air to it form the wheel arch.
Looked into the ducting recently and I can make a flexable bit of 3" pipng go form the wheel arch to just under where the POD sits.
So then I will just seal the surround ing hot off as best I can, and that'll do me.
AE82 FXGT
Postby bluemaumau » Mon Apr 16, 2007 12:58 am
yeaq im planning the same as above,
im 99%the stock fuel system is sweet, save your money or spend it on other improvements
Re: AE101 4A-GZE Air Intake Options
Postby Crucible » Mon Apr 16, 2007 2:08 pm
DECEVR wrote:But before i start mucking about, what is generally done in this area? and can i perhaps have some pics of what others have done, or suggest. I have a pulley kit otw and plan on sorting this and then beefing up the fueling with some MR2 injectors and a larger fuel pump (i figure a good search will give me all the info i need on this)
I personally wouldnt worry about a bigger pump, a stock pump and injectors will be ok upto 14 psi. You have boost cut at 15psi anyway with ae101 ecus so its pointless really. Bigger injectors will just make it run rich if running them with a stock e.c.u.
Apart from a bigger pulley you are better spending the money on a water2air setup which would be a far better gain in my opinion, and put the stock airbox back in with a k&n panel, no gain with pods in a hot engine bay.
Crucible
Real Life Mechanic
Postby DB4G63 » Mon Apr 16, 2007 2:09 pm
What makes it a GTZ-R??
Is this some aftermarket sticky or something...
I have been contemplating the airbox as well, since the previous owner threw a poddy in mine too. the default postion appears to very poor for this sort of thing.
Someone told me the stock airbox with a decent K&N is a good idea.
"If I'm a child that means you're a pedophile, and I'll be damned if i'm going stand here and take this from a pervert."
Wheels: AE101 1993 GTZ Trueno (S/C)
DB4G63
Postby Crucible » Mon Apr 16, 2007 6:28 pm
DB4G63 wrote:What makes it a GTZ-R??
wtf?? GTZ - R??? first time Ive heard of that one 8O
hope he wasnt trying to talk it up with a sticker lol
Crucible
Real Life Mechanic
damn pod filters
Postby ze-fighter » Tue Apr 17, 2007 8:58 am
Yea iv seen that car for sale on trademe. Looked pretty mint apart from the sticker and bov. made me think of hondas when I saw the R. I too have been the victim of pod filter vandals on my gtz, so let me know how your guys airboxes turn out as iv been frantically searching for a standard airbox.
4agze >>> killing hondas since aaages ago
ze-fighter
Postby bluemaumau » Tue Apr 17, 2007 11:04 am
im going to do one real soon so ill post it up.
Postby XSVWGN » Tue Apr 17, 2007 11:55 am
best option would be move battery to the boot or similar area and get a custom pipe made up from your inlet to behind your headlight. Then get someone to fabricate an alluminium box made up to sit over the filter etc...done deal
i want to look at a water to air setup? anyone know how to go about doing this?
2008 Kia rio - work car
XSVWGN
Postby bluemaumau » Tue Apr 17, 2007 12:02 pm
for the intake?
ive come up with a idea of rotating my battery 90degrees, close to the overflow bottle,
this would require a new batery tray, and securing mounts, but it seems pretty easy, ill then make a box around the pod, and runn a pipe thru the hole, in the engine bay to a collector just below the bumper.
sweet
Postby Crucible » Tue Apr 17, 2007 6:51 pm
XSVWGN wrote: i want to look at a water to air setup? anyone know how to go about doing this?
use a subaru legacy one matt, enough of them on the road these days with frontmounts.
Crucible
Real Life Mechanic
