remote thermostat pipes
Postby ke36 » Tue Apr 17, 2007 7:05 pm
hey guys im putting an ae82 remote thermostat in another car (non toyota) and just have a couple of questions to ask
which of the two small pipes on the side are the sensor line for the thermostat and the heater line?
im not familiar with 4age motors so dont know what goes where etc in this picture
obviously bottom pipe to bottom rad pipe and big top pipe goes to water pump
i assume the pipe coming from the rear of the engine is the heater outlet/return after its been in the cabin and the one exiting the front by the radiator top hose is the sensor line as it just goes to the thermostat but just want to make sure
also what temp do they open at?i assume somewhere around 80-85?
cheers guys
F**K THAT NEW S**T WE RIDIN OLD SKOOL
ke36
Postby KinLoud » Tue Apr 17, 2007 8:43 pm
Look at my past posts - might help you work it out (pics of an AE92 fxgt).
viewtopic.php?t=34544&highlight=thermostat
Might have the info you want.
Ken
Ham
021 408 863
Postby ke36 » Tue Apr 17, 2007 9:18 pm
yea saw that post in my search mate looks like iv got it right and thats part of what i was basing my assumptions off but just want to be 100% sure before i start to plumb it up
ke36
Postby KinLoud » Tue Apr 17, 2007 9:52 pm
Hah - well done in the search department! A bag of Toyspeed brand chocolate fish will be in the post to you (as soon as we can convince someone to make them for us)... :)
Who votes that we make this thread a FAQ topic?
Ken
Ham
021 408 863
Postby l1ttle_d3vil » Tue Apr 17, 2007 10:34 pm
ive got the exact same setup on my ke70 4age, will get some pics for you tomorrow if you want...?
Postby ke36 » Wed Apr 18, 2007 7:35 pm
yea mate thatd be awesome, as many ways as i can se people have done it is good cos gives ideas to mount etc as mine will be going in a rwd car
also if you could work out which pipe is ur sensor pipe and which is just the heater pipe
as i said im 99% sure but dont wana risk it amd either have to re run the pipes etc or even worse cook an engine
ke36
Postby AE25 » Fri Apr 20, 2007 12:29 am
we've done exact same setup as first pic in a fwd turned rwd 4age in a ke30.. mounted an ae82 remote thermostat under the intake pretty neatly. modded hot bypass line a little bit for better fit under the intake where hot water comes out of engine at the front and added a water line up to the throttle idle control wax valve. the heater line comes off back of head, thru the heater core and into the back of the thermostat.
E2 & E7 fanatic
http://www.toycrazy.net
AE25
Postby ke36 » Thu Apr 26, 2007 10:36 pm
cheers mate so looks like i had it right in the first pic
thanks
ke36
Users browsing this forum: Bing [Bot] and 8 guests
