4afe dash wiring
4afe dash wiring
Postby bluemaumau » Tue Apr 17, 2007 9:45 pm
can anyone point me in the direction of a 4afe dash pinout. im specificallly interested in the oil pressure/level light.
as mine is constantly on.
ive replaced the sender unit and i know its got oil, so it must just not be loomed up
cheers in advance 8)
Postby KinLoud » Tue Apr 17, 2007 9:57 pm
Possibly you are using a pressure sender (gives a variable voltage depending on the pressure to operate a gauge) with your oil light setup. An oil light usually has a pressure switch that is earthed when the pressure is zero or low (causing the oil light to shine) and is open circuit when the pressure is ok (no oil light).
Ken
Ham
021 408 863
Postby bluemaumau » Tue Apr 17, 2007 9:59 pm
true, im using a 4agze sender obviously and a 4afe dash.
how would i go about fixing this ken?
