4agze DLI
4agze DLI
Postby ze-fighter » Wed Apr 18, 2007 6:52 pm
Ok, just got my car back from Counties Toyota. They mentioned this one thing about my distributor needing the O Ring replaced. I replied that I have coil packs. They then told me it would be a signal generator o ring that needs replacing instead.
Iv done a search, but it doesnt really cover that much about DLI o rings?
Any help is much appreciated.
Brad.
4agze >>> killing hondas since aaages ago
ze-fighter
Postby bluemaumau » Wed Apr 18, 2007 7:00 pm
probley the CAS o ring
Postby ze-fighter » Wed Apr 18, 2007 7:07 pm
yea? il do a search on that then. cheers dude
ze-fighter
Postby Zak » Wed Apr 18, 2007 7:32 pm
It's just a simple unbolt. replace o ring. bolt on. then time the engine.
Takes about 30min at most if you have a timing light a small peice of wire and a 12mm spaner.
If you want more help or what ever just ask 8)
Zak
Postby ChaosAD » Wed Apr 18, 2007 8:15 pm
Dunno about the DLI, but with the bluetops its usually the shaft seal inside the distributor thats leaking.
But just replace the o-ring and see
ChaosAD
Postby matt dunn » Wed Apr 18, 2007 8:17 pm
if I was doing it i'd first pull the cap off the CAS and mark it like a normal dist as they can be a bastard to time as there is nothing you can see and the drive turns as you pull it out and push it back in.
Postby ChaosAD » Wed Apr 18, 2007 8:24 pm
and see if theres oil in there too
ChaosAD
Postby Zak » Wed Apr 18, 2007 9:31 pm
That would be a very good idea if you've never done one before.
Zak
Postby ze-fighter » Thu Apr 19, 2007 9:21 am
thanks guys. so i should look at doing the o ring and possibly the shaft seal also. il post up again if i need more help. thanks again
ze-fighter
