Aircon Removal
Aircon Removal
Postby Illusionz » Thu Apr 19, 2007 2:56 pm
Hi all
I have a ST205 Celica i was wondering does anyone know if when you remove the aircon pump if you need to buy a new belt or any other complications that i could come across?
Illusionz
Postby 92mr2paddy » Thu Apr 19, 2007 3:46 pm
hey, on my 3sgte engine when i removed my air con, the air con was driven by a seperate belt, so simply unbolt the air con unit and pipes then cut belt and there you have it.
now if your cambelt runs the air con as well, you will need to take the air con unit out and get a tensioner made up for where the air con unit used to sit, IF they dont have a belt that will just iliminate the air con altogether.
8)
92mr2paddy
