Anyone know about Telstars?
Postby ollieboy » Sat Apr 21, 2007 4:16 pm
My friend has a 1990 Telstar and its making a ticking sound like loose tappets. Do these have adjustable tappets and if so would anyone be able to give me the specs on what they need to be set to?
Ollie
ollieboy
Re: Anyone know about Telstars?
Postby Crucible » Sat Apr 21, 2007 5:16 pm
ollieboy wrote:My friend has a 1990 Telstar and its making a ticking sound like loose tappets. Do these have adjustable tappets and if so would anyone be able to give me the specs on what they need to be set to?
Ollie
pretty sure they're hydraulic .... run a flush then change the oil and use MBL8 additive, works really good on mitsi and Subaru hyd tappets.
Crucible
Real Life Mechanic
Postby Zak » Sat Apr 21, 2007 6:15 pm
Depends on the engine, id its a DOHC one it'll be hydrolic, if it's a SHOC, it's most likely a tappet system.
Zak
Postby Blackstripe » Sat Apr 21, 2007 6:47 pm
Try www.amazd.co.nz. there are a few Telstars, if its a dohc itll be a BP engine and they would know quite a bit about those lol
I live my life 1000RPM at a time. Nothing else matters, not the blown piston rings, the wasted distributor, the popping oil cap and all that other stuff. For those 8000RPM or more, im free.
Blackstripe
Postby Zak » Sat Apr 21, 2007 7:30 pm
Na, if it's a DOHC it'll be a FE engine, similar, but alot stronger. Some one from amazd might know, Fraud Motorsport on there has built a few of them so he'd be the one to talk to.
Zak
Postby Alex B » Sat Apr 21, 2007 7:36 pm
SOHC use hydrolic tappits, my fathers old 88 626 was horrible for them when cold.
Postby ollieboy » Sat Apr 21, 2007 11:15 pm
Thanks for help guys. Will do engine flush and see, if that doesnt work will go to the website mentioned.
ollieboy
Postby Rob » Mon Apr 23, 2007 8:37 pm
Sohc also has adjustable tappets and the hardening wears off really easily
due to fords and mazdas being shit haha
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby fangsport » Tue Apr 24, 2007 1:04 am
it's the self destruct timer, be sneaky and out fox it with a litre of petrol and a match :twisted:
fangsport
