tdc 16v
tdc 16v
Postby bluemaumau » Sat Apr 21, 2007 7:20 pm
am i right in asumming when piston 1 is at TDC, inlet #3 is depressed by the cam lobe and exhaust #2 is also depressed.
cheers, want to make sure so i dont have to pull the thing apart AGAIN 8)
Postby mr30%jr » Sun Apr 22, 2007 10:33 am
theres a wee trick of you have the cam cover on with the the oil fillter cap theres a little dimple in the cam this should line up with the egde of the oil filler ( the halfway of the filler ) if your cambelts on right that will be TDC
mr30%jr
Postby bluemaumau » Sun Apr 22, 2007 11:02 am
my cambelt is off
Postby matt dunn » Sun Apr 22, 2007 12:39 pm
what are you actually trying to do? set the cam timing?
Postby bluemaumau » Sun Apr 22, 2007 5:26 pm
yup
i did my valve clearances, ages ago and whilst organising a new shim i forgot wether #1 or #4 was at tdc
Postby matt dunn » Sun Apr 22, 2007 7:38 pm
bluemaumau wrote:yup
Ok,
as far as the pistons and block is concerned there is no difference between TDC no1 and TDC no4. They both occour at the same time.
Just line up the crnka pulley at TDC ( both piston 1 & 4 will be up )
and then line up the cam markls on the pulley's to make it TDC number 1.
The crank cannot be 360 degree's out.
Postby bluemaumau » Sun Apr 22, 2007 9:42 pm
oh true i get it why they say check 8 clearances at #1 at tdc and 8 at #4,
because the crank spins twice as fast correct.
:oops: :lol:
Postby mr30%jr » Sun Apr 22, 2007 11:54 pm
get a BGB on 4ages...
theres marks on the cam gears n shit for that
mr30%jr
