I decided to try to take this measure to call in some more horses
I've dug out the WTA IC ECU from the centre console, got a box
with P/N 89255-20030 slightly smaller than a pack of cigarettes
and having a 10pin connector.
I've pulled the cable from it and put ignition on.
This resulted in the pump running instantly and apparently
continuously and now I've got a check engine code 54.
I haven't tried to drive around because I suspect it may
have gotten into some sort of safe mode. I would like to
do things with a bit more knowledge than that. I've also
disassembled the box and found that there is a fairly
complicated circuit inside.
Has anyone figured out the pinout of this thing already?
Any other clues?
