Stiffest possible shocks for z10,a61,ae86?????
Postby MrDori » Sun Apr 22, 2007 10:16 pm
Need to find out what are the stiffest Gas shock insrts i can source for my z10, would like them to be as short as possible, like 50-61mm sorter than stock. i beleive ae92 size is about what i want but needa bell hella stiff.
Garage Slipway- Super rarity
1g-gte powered gx61 creditstar
MrDori
Postby fangsport » Sun Apr 22, 2007 10:53 pm
scope out something from a 3-5 tonne truck, cut the mount off the bottom and fit a spacer??
fangsport
Postby deaf_rattle » Mon Apr 23, 2007 10:46 am
i can find the part number for what i ran if needed.
I had to run a spacer in the housingas it was about 2inches shorter than stock
Postby rwd_mayhem » Mon Apr 23, 2007 1:32 pm
deaf_rattle wrote:i can find the part number for what i ran if needed.
where do you get the spacer from?
current: 1975 Valiant Regel
previous: 1980 mazda 626, 4AGE AE70 sedan, AE70 sedan, mk2 escort, KP60 starlet, TE71 liftback X2
rwd_mayhem
Postby deaf_rattle » Mon Apr 23, 2007 2:59 pm
stocks supplied it with the shocks.
But you just need to buy some thick walled pipe (4mm wall) and then have it cut to the length you need
Postby MrDori » Mon Apr 23, 2007 8:57 pm
yea done that, what rate springs did you run?
I wont need a spacer as ill chop the strut down to suit as to keep good amounts of travel
MrDori
Postby big_boy » Tue Apr 24, 2007 12:25 am
have some old air ones if any one wants to by them i know with 3 motors in the back (5M`s) it droped about 3mm witch was quite impressive that was on 120psi when then let all the air out & sat it on the bump stops to get them out :)
for sale EE90
big_boy
