fivebob wrote:Depends on how much boost, and how you plan on varying the compression ratio. The restictor shouldn't be a problem if you have freedom to place it where you like (i.e. as far away from the turbo inlet as possible)
IMHO thicker headgaskets are a bad idea as the promote detonation by reducing the effectiveness of the squish area, so I'd stick with the whatever CR you have when fitting a stock H/G (or even a thinner one) which IIRC is about 9:1. Careful tuning using Minimum Advance for Best Torque principles should be safe.
Water injection would allow you to run a bit more compression
strx7 wrote:i'm running 9.5:1 on my 5S cranked, 3SGTE with 264 degree cams.
RedMist wrote:strx7 wrote:i'm running 9.5:1 on my 5S cranked, 3SGTE with 264 degree cams.
Your dynamic compression will be considerably lower than mine given the duration of your cams.
RedMist wrote:The restrictor has to sit bolted to the compressor housing and the restriction must be no further than 50mm upstream of the blades. So its most certainly going to create issues in terms of volume of air.
My only real option was to increase compression ratios. I dont like thicker head gaskets or removing squish bands. The Wisecos are already here so I cant alter the dome. So it was either plane the head or install my TRD head gasket. Wiseco rate the pistons at 9.0:1 CR probably due to the larger bore size (86.5mm).
I have two new headgaskets, one stock Toyota and the second a TRD. I have no preference as to which I use.
I possibly presented the question incorrectly. If I'm aiming for a 300hp enigne what should my CR be given the following.
Cams will also be replaced when I have the cash so speccing them now should be advisable. A very short duration, high lift intake cam, and a very long duration exhaust cam.
Antilag (Group N augmented by throttle bypass. )
Water Injection (ST205)
Stock WTA with spray bar
Cold air intake
Wiscos
Eagle Rods
ACL bearings
LEM3, IAT boost adjust.
LC1 wideband.
Knock probably wont work depending on how much noise it picks up from the solid engine mounts and underbody protection.
My thinking was, because of the flow restrictions I would want a reasonably high CR around 9.5 to one. However I know nothing about restrictors or hair dryers. Lowest CR I've ever run was 12.5:1.
fivebob wrote:BastardsAll the info I have suggests that retrictor flow can be increased if it's place well before the turbo.
fivebob wrote:At 50mm you'd have problems with getting enough taper after the restrictor to match the turbo inlet without causing flow problems. Is the shape of the restrictor fixed, or does it just have to be 36mm at it's narrowest point?
I possibly presented the question incorrectly. If I'm aiming for a 300hp enigne what should my CR be given the followingIs that 300HP at the wheels?
If so, then you'll need a better turbo than the CT20B. Which in a 4WD would be pushed to get more than 280-290HP. Best I've seen is around 310rwhp on a MR2. Given the 4wd, and the fact that the compressor will be operating at reduced efficiency and therefore heating the intake charge more, then I think you'd be lucky to see 275whp
fivebob wrote:I wouldn't recommend this strategy, 264's have been proven to give the best overall power characteristics on 3S-GTEs. see http://www.cj-motorsports.com/camtest.htm for graphs of all the combinations.
RedMist wrote:fivebob wrote:At 50mm you'd have problems with getting enough taper after the restrictor to match the turbo inlet without causing flow problems. Is the shape of the restrictor fixed, or does it just have to be 36mm at it's narrowest point?
Its certainly going to pose issues for a turbo like the CT20b. Shape is open, but we have completed some basic flow tests and the optimal shape at the moment seems to be a bellmouth on entry to the restrictor. It appears a ramp (as pictured in pg 34) attempts to force all air more centrally after the restriction. So we are currently spinning up a bellmouth onto the 36mm restriction then a flare out onto the compressor housing of the CT20b.
The cams arent to attempt and get more power, although they may be useful to shift as much torque down the curve as possible. They are a simple method to 1. work around the intake restrictions. 2 get as much exhaust flow as possible for a quick spool.
With CR: I think I'll stick conservative and go 9.5:1
Mr Revhead wrote:dont stress too much about 20 odd hp in a rally car....
work on your driving
vvega wrote:can you run a later modle head redmist?? perhps a beams jobbie ?
fivebob wrote:Be careful that you don't have too steep a taper after the throat, as that will cause the airflow to detach, create turbulence and reduce flow. If a straight taper is much more than about 8° then I would suggest making it a bellmouth on exit from the throat. IME what happens after the throat is as important as what happens before. Also a radius before and after the parallel section of the throat will help keep the flow attached.
RedMist wrote:fivebob wrote:Be careful that you don't have too steep a taper after the throat, as that will cause the airflow to detach, create turbulence and reduce flow. If a straight taper is much more than about 8° then I would suggest making it a bellmouth on exit from the throat. IME what happens after the throat is as important as what happens before. Also a radius before and after the parallel section of the throat will help keep the flow attached.
I no longer have the CT20b here as the restrictor is being spun-up and mounted. But your saying if I cant achieve an 8 degree ramp I should simply plate off the intake at 50mm from the blades, cut a hole in it and bellmouth the opening to 36mm? We have already done flow tests using an entry ramp and it just doesnt aid flow. So no ramps either side? I'm going to have to flow test this one.
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
