Installing arp rod bolts into 4agze
Postby IH8TEC » Mon Apr 23, 2007 4:51 pm
Right, here's my dilemma.
went to install the ARP rodbolts yesterday. with head on, tried to take old ones out, and they just wouldn't budge. so basically i'm taking the head off to take the pistons and rods out to change the rod bolts.
now mechanic is saying i may need to hone out the rods, which would also mean new bearings i'm guessing, as the arp ones are torqued more than the std 4agze ones.
has anyone else been through this and had the hassle as mentioned above? or was it a straight swap for you.
thanks
brendon
Postby Mr Revhead » Mon Apr 23, 2007 5:49 pm
why does he say hone the rods? did you run a bearing?
if you do that then yes you will need new bearings
otherwise reassemble and check clearanaces, as you should always do
Postby IH8TEC » Mon Apr 23, 2007 5:58 pm
well thats what i thought warrick, i dont see how the clearances will change that much, maybe slightly.
and nope, no run bearings :D at least taking the head off to get them will give me a good chance to inspect the motor and how it's held up so far before i ram more boost through it
Postby ChaosAD » Mon Apr 23, 2007 6:01 pm
I think there is a tiny bit of machining to do to get them to fit, but dont quote me on it.
I would have thought the bearings should be replaced.
ChaosAD
Postby Mr Revhead » Mon Apr 23, 2007 6:02 pm
if they are the right ones, there should be no machining needed.
some places sell chev ones as 4age ones.... they need maching on some blocks
Postby IH8TEC » Mon Apr 23, 2007 6:02 pm
ChaosAD wrote:I think there is a tiny bit of machining to do to get them to fit, but dont quote me on it.
why they perfectly fine and only done about 7,000kms
Postby ChaosAD » Mon Apr 23, 2007 7:05 pm
May have been the block that needed machining. I thought the bearings would need replacing beacuse of the different torque settings being used.
http://www.club4ag.com/faq%20and%20tech_pages/Connecting%20ROD.html
ChaosAD
Postby CAMB01 » Mon Apr 23, 2007 8:52 pm
Ive used ARP rod bolts on my 4ages and 4agze before. Was just a straight swap.
Although when i replaced them i was rebuilding the motors.
But yeah straight swap no machining, just used a press to press them in.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby IH8TEC » Mon Apr 23, 2007 9:21 pm
cher,
Postby matt dunn » Tue Apr 24, 2007 12:32 am
ChaosAD wrote:May have been the block that needed machining. I thought the bearings would need replacing beacuse of the different torque settings being used.
Why?
the con rod and con rod cap are not going to squish together any further no matter how tight you do them.
the difference in torque spec's is the difference in the stretch of the rod bolts.
Postby IH8TEC » Tue Apr 24, 2007 8:22 am
so in theory it should be a straight swap over matt? but off coarse still check clearances.
Postby Bazda » Tue Apr 24, 2007 10:18 pm
CAMB01 wrote:Ive used ARP rod bolts on my 4ages and 4agze before. Was just a straight swap.
sometimes when you do this, it can slighty put the cap out, ever so slightly and will wear the bearing faster.
Better to check the roundness of the hole first and clearances.
Postby Crucible » Tue Apr 24, 2007 10:43 pm
why even bother with arp bolts?
are stock gze ones known to fail? am I missing something here lol? :P
Crucible
Real Life Mechanic
Postby IH8TEC » Tue Apr 24, 2007 10:45 pm
i'm planning on running 25psi to 8000rpm. bit of a safety measure i guess, std ones have been fine with running 20psi.
Postby Mr Revhead » Wed Apr 25, 2007 10:48 am
stock ones have been known to let go after reusing.
also they are the weakest link down below. unless your using blacktop rods!
Postby Crucible » Wed Apr 25, 2007 10:20 pm
It doesnt give me much piece of mind knowing that ae101's have the smallest rods :?
oh well give it heaps and see what happens aye :P
Crucible
Real Life Mechanic
Postby Mr Revhead » Wed Apr 25, 2007 10:30 pm
no, ae111s do
ae101s have very strong rods
Postby Bazda » Wed Apr 25, 2007 10:44 pm
Mr Revhead wrote:no, ae111s do
but still not as big as early gze's
Postby Mr Revhead » Wed Apr 25, 2007 10:48 pm
nope not as big.
but more than up 2 99.99% of applications!
Postby Crucible » Wed Apr 25, 2007 11:12 pm
I meant as in smallport vs bigport gze.
Crucible
Real Life Mechanic
