AceSniper wrote:4agze igniters wont work on a link, but the coils will so if u use 20v leads u could use them with a mitsi or link igniter.
you wont need cas as your link will be using the cas in your dizzy so you need to keep the dizzy there, just any mitsi that has coil packs and is 4cyl get the igniter and coils inc plugs
sergei wrote:you can make CAS out of your 4AGE distributor, internally (as in triggers) it is identical to GZE CAS, what you need to do is to remove the high tension distributor part and make a cover for whats left.
