Pelo wrote:Turned out the exhaust turbine wheel had disintegrated. Always possible with ceramic turbines.
postfach wrote:are all the joins on the intercooler piping done up properly? are any of the pipes plastic? check the joins and look for cracks in any plastic piping.
fivebob wrote:Blocked/collaspsed Catalytic Converter?
Or perhaps something to do with your oil leak that you posted in viewtopic.php?p=564823
sleepy wrote:Have you taken the manifold cover off and had a look at the manifold? Could just be the manifold wraped so badly that the exhaust gases are just rushing out. Its a common problem on the gt-t's.
If you have a wastegate, maybe its open all the time, same goes if you have a actuator instead of a wastegate. Could also be the gaskets have had enough.
The noise tells me that its exhaust gases leaking, which is why your car isn't boosting.
fivebob wrote:When you say it got 4mm of sideways play, do you mean radial or axial play?
Radial play is when you grab the end of the turbine and move it up and down, left and right around the radius of the shaft. Axial play (end float) is where you can move it in and out of the housing along the axis of the shaft.
Radial play in the bearings could cause the bent fins and the wear in the housing and would be caused by worn bearings. Axial play might also cause similar symptoms, but other than a loose nut I can't think of a cause for this.
evil_si wrote:other wise compressor surge and backfeeding chchchch noise will make the compressor nut unwind and disintegrate
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
