Anyone put a 2jzgte into a na mkiv supra before?
Postby Coke » Sun Apr 29, 2007 2:21 pm
Im doing this swap soon....
The engine is a 2jzgte form a non vvti supra
Whats the dealio with the na auto d/shaft and a TT auto d/shaft? are they the same? Are auto tt soarer diffs compatable with mkiv's?
Also ive heard the dash isnt plug and play and that custom wiring is needed? Anyone know about this?
Any info would be mean good :)
Coke
Postby postfach » Mon Apr 30, 2007 10:25 am
I don't know about the wiring but the driveshaft will be the same as they both use the A340E transmission. 99% sure the supra and soarer diff is the same.
postfach
Postby Coke » Mon Apr 30, 2007 3:42 pm
Yea it know they have the same tranny code etc...but the auto's are supposedly really different.
When are you going single?
Coke
Postby mr_monkey » Mon Apr 30, 2007 6:57 pm
yeah, TT mk4 supra autos have extra clutch packs or something apparantly. same tranny code but quite different inside from everything ive read.
-Nathan
Previous rides: 1992 Toyota Trueno, 1992 Nissan GTI-R, 1985 Toyota AW11, 1990 Toyota SW20 Turbo, 1994 Toyota Supra Twin turbo, 1991 Toyota Soarer Turbo, 1991 nissan Safari
Cogent wrote: there is a fraudulent cogent-post in your sig and i insist that you cease displaying it immediately or else i'll track you down and perform acts of homosexuality on your face
mr_monkey
Postby postfach » Mon Apr 30, 2007 9:26 pm
yeah of course the inside of the box is different for the turbo, but the casing is the same, so the length of the box is the same, and the spline on the driveshaft is also the same. auto na to auto tt conversion = don't need to change the driveshaft.
going single turbo after the rest of the car is set up for track, after going to a few trackdays its blatantly obvious that for now i have plenty of power and having a proper track suspension, brake and tire setup is going to be way more beneficial.
postfach
