carb troubles
carb troubles
Postby 79rolla » Sun Apr 29, 2007 2:47 pm
hey im gettin annoyd with my carb on my 4k
the problem is when i floor it while doing low revs it starvs for a second when the second barril opens up causing the car to loose all pwer before burning off if you can understand what im saying
is there any eysy way to fix this?? tuning maby??
thnx
(sorry bout spelling)
past: AE82 FXGT
79rolla
Postby Crucible » Sun Apr 29, 2007 5:59 pm
If you mean its hesitating off idle when you take off at the lights, it sounds like a prob with your accelerator pump n/w. Or do you mean its more when the secondaries are opening?, are they mechanical or vacuum on those?
I used to mess with Nikki 4 barrels on Rotarys, and convert them to from vac to mech. It used to have a big flatspot when the secs come in because it had no sec acc pump like holley double pumpers..so it may be a prob in that area.
Basically throw a kit at it and try that...
Crucible
Real Life Mechanic
Postby 79rolla » Sun Apr 29, 2007 7:01 pm
its mec its hapnin when the second barril opens up
it didint do it when the second wasint working lol
is there a eysy fix? i not rele preperd to spend muny on it atm i can live with it till i do a transplant next yeair
past: AE82 FXGT
79rolla
Postby Crucible » Sun Apr 29, 2007 7:13 pm
you say they never worked, did you converted it to mech sec from vacuum ?or are they factory mechanically opened?.
because if you have you will get a lean spot when they open. you wont get the prob when its vacuum because the servo opens them slow.
Crucible
Real Life Mechanic
Postby 79rolla » Sun Apr 29, 2007 8:59 pm
its factory mec and yea im trying to see if there is a way to get around the leain spot eysily. can you tune it to stop the problem?
thnx
past: AE82 FXGT
79rolla
Postby Crucible » Sun Apr 29, 2007 9:40 pm
79rolla wrote:its factory mec and yea im trying to see if there is a way to get around the leain spot eysily. can you tune it to stop the problem?
thnx
Im not to sure if you can, for example on Holley carbs, they have secondary accelerator pumps (ie Double Pumper) to start enrichening the secs when the butterflys begin to open.
That prevents it leaning out and bogging. Have you checked to see if its got fuel out the discharge tube?
Crucible
Real Life Mechanic
Postby 79rolla » Sun Apr 29, 2007 11:32 pm
na i havint relly looked at it that closely but i dont relly no wjat im suposta be looking for thats y i poseted here lol
thnx
past: AE82 FXGT
79rolla
Postby Jdawg » Sun Apr 29, 2007 11:53 pm
It sounds like your secondary is opening to early, adjust linkage for later opening.
If it was opening to late you would feel the engine power just drop off, no lag, then pick up again
Jdawg
Postby Crucible » Mon Apr 30, 2007 10:20 pm
Jdawg wrote:It sounds like your secondary is opening to early, adjust linkage for later opening.
what you may find though if you adjust them to open later you may not get them to open fully.
good point though and worth a look....
Crucible
Real Life Mechanic
