What's the advantages of a poddie
Postby tayis01p » Wed May 02, 2007 3:06 pm
Obviously i'll get a better induction sound on my blacktop 20V but what about power (will it go down) should I buy an intake pipe? and finally what about economy? so many questions
tayis01p
Postby slighty_sykotic » Wed May 02, 2007 3:44 pm
Should search...
Basicaly, most of the time you are better off getting a k&n panel filter and putting it in your std airbox.
If you get a pod, get a real one, not a $30 one from supercheap.
The pod will have to be sheilded from the hot engine air, and pref have a nice feed of cold air comming into it. Have a search for people's cold air box's they have made.
If done properly, you will free up a couple of hp if your lucky.
Done bad, and you will go backwards, and run the risk of killing your motor (sucking in water from badly placed pod).
--Sykotic
slighty_sykotic
Postby Silent Knight » Wed May 02, 2007 4:24 pm
Street Cred. 8)
Silent Knight
Postby slighty_sykotic » Wed May 02, 2007 4:28 pm
Street Cred. 8)
lol, with who?
I mean,
wit wa gansta ow?
slighty_sykotic
Postby tayis01p » Wed May 02, 2007 4:34 pm
Street Cred. 8)
Yeah well its just that ive read and heard so many contradicting things about after market performance parts, and not having a dyno at home I was wanting to get some opinions. shot
tayis01p
Postby Go_the_mini » Wed May 02, 2007 4:44 pm
Hp wise you probebly wont notice a pod but they are usually shinny and make your engine bay look nice, Obiously more air is going to help ( More so if its cold) and with a decent intake you should get a better trottle response depending on what your putting it on, However if its not air tight your gunna end up with vaccum leaks so you will be traveling at half the speed for twice the gas
Go_the_mini
Postby deaf_rattle » Wed May 02, 2007 7:01 pm
slighty_sykotic wrote:Should search...
there is hardly any restriction in a stock filter, you are better off just improving flow to and from stock air box.
Postby Prymal » Wed May 02, 2007 8:09 pm
it makes teh sic noises bro aye ??
fking useless if its not set up correctly and shielded in the engine bay ..
Kids and wannabe fast and furious types will put the pods in for the bling , but i truely think that many dont even run their minds over how they work , whats best in how they get placed , and what improvemenbts over a stock airbox there is
Prymal
Postby Emperor » Wed May 02, 2007 9:54 pm
Build a new box and put a K&N panel in it, or just put better air flow to the stock box.
Seen a really nice setup in a NA RX7, heat wrapped box, with panel filter, and two big fat pipes straight from the front into the box
Emperor
Postby frost » Wed May 02, 2007 10:09 pm
dont need filters just suck atmo
Postby tayis01p » Fri May 04, 2007 3:37 pm
Cheers for your help guys.
tayis01p
Postby cogent » Fri May 04, 2007 3:53 pm
If it helps, this is how our blacktop in our AE110 has the intake set up
(yes i realise the catch-can is set up wrong, i was correcting it in that photo :D )
cogent
Postby Loudtoy » Sat May 05, 2007 9:04 am
Hey thats almost exactly the setup i had in my 101 with sivlertop only my intake pipe was bigger and was one mandrel bend and i also had the afm as well obviously.
Btw it works even better like this if when you are at a track event or some sort of speed trial if you take the left hand headlight out.
To give anyone looking at this a rough idea of cost for me it was
$47 for the battery box to relocate battery
$30 for the cable to move battery to boot
$60 for the circuit breaker
$15 for the pipe
Free stainless for the heat sheild
$23 for the two joiners i needed to join pipe to inlet plenum and afm
and i got given my catch can for my birthday from my little brother so not sure how much
$80 for the pod
$100 for 2 dyno runs before and after
Total gain for pod system nearly same as above was 4kW atw :)
May have been slightly colder on second run as one was summer and one was winter but not 4kW worth in it
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby solitaire » Sat May 05, 2007 5:32 pm
tech faq maybe? excellent price run down and actual dyno results...
AE92, KZJ120, KDJ120
solitaire
