Reshelling a pre 96 import (can I change over the odometer)?
Postby ~SlideWays~ » Thu May 03, 2007 12:09 pm
Im thinking of doing this, with a *cough*mitsi*cough but the mmc forum doesn't like to share info as much as Toyspeed :)
What I would do is import a non compliable pre 96 car then transplant all of the good bits into a NZ reg'd shell then certify it.
What I was wondering is, can I put the odometer from the import in then get it cert'd like that? Or will it cause problems since the km's are recorded at each WOF check?
~SlideWays~
Postby 2LTR Rona » Thu May 03, 2007 12:15 pm
the way i see it.....what you are wanting to do is no different from average joe bloggs getting a new / second hand unit for their car off trademe & throwing that in.
Have a chat to Distrb though cause he swapped over this in his Tezza :wink: pretty sure he just unbolted & then bolted in
2002 Altezza, 1974 KE25
2LTR Rona
Postby ~SlideWays~ » Thu May 03, 2007 12:18 pm
2LTR Rona wrote:the way i see it.....what you are wanting to do is no different from average joe bloggs getting a new / second hand unit for their car off trademe & throwing that in.
Pfft why would I want to talk to that dick? :lol: /will do
Main concern is that the import is likely to have way less k's than the nz shell.
~SlideWays~
Postby 2LTR Rona » Thu May 03, 2007 12:30 pm
I see your first point :P :lol:
yeah thats a point.....but then you take the KE as an example & I highly doubt the OD is the original one, usually they get swapped at some point in time, haven't had issues with that.
You could also have a word to the Greekman...given his daily job :wink:
2LTR Rona
Postby neo » Thu May 03, 2007 2:07 pm
Swapping the speedo isnt 'really' an issue, it just gets highlighted if you do one of those online vehicle look ups.
Playing with the speedo numbers isn't as easy as it looks... :wink:
neo
Postby Mr Revhead » Thu May 03, 2007 3:43 pm
swapping the speedo isnt the concern
itll be the body your putting it in
reshelling is a bs term
you cant reshell monoque car!
so you need to talk to the authorities about that
Postby ~SlideWays~ » Thu May 03, 2007 5:19 pm
Monocoque you mean?
What do you mean BS term, all Im talking about is taking a 4wd Lancer of the same year/shape, strip it, then swap over all of the evo go go bits then get is cert'd as a Lancer with evo gear.
I see no BS? :lol:
~SlideWays~
Postby Mr Revhead » Thu May 03, 2007 5:22 pm
:lol: onecock then
hows that? :twisted:
maybe its from my days of reading british magazines, but reshell = keep same number plate and identity and rebody a car. as todays cars are of monocoque construction, you cant do that. your actually swapping the plates etc to another car. which you cannot do.
Postby RomanV » Thu May 03, 2007 5:26 pm
So in other words you know exactly what he's talking about, but you feel obliged to make a fuss about it anyway, and clutter his thread?
Ban the spammer! :p
Postby ~SlideWays~ » Thu May 03, 2007 5:26 pm
Mr Revhead wrote::lol: onecock then
noooo thats not what I mean.
Me = get NZ registered road legal 4wd lancer for cheap. Import non-compliable evo of same shape lancer. Then swap the bits into the NZ registered one and have it certified as a modified lancer.
Then use the unregistered evo shell as a dog kennel or something. :lol:
~SlideWays~
Postby Mr Revhead » Thu May 03, 2007 5:26 pm
oh.... KEEP THE 86 FOOOOOOL
Postby ~SlideWays~ » Thu May 03, 2007 5:27 pm
RomanV wrote:So in other words you know exactly what he's talking about, but you feel obliged to make a fuss about it anyway, and clutter his thread?
Ban the spammer! :p
Can he ban himself (being a mod) or would the TS world implode into itself somehow?
~SlideWays~
Postby ~SlideWays~ » Thu May 03, 2007 5:28 pm
Mr Revhead wrote:oh.... KEEP THE 86 FOOOOOOL
yeah yeah... :lol:
~SlideWays~
Postby Mr Revhead » Thu May 03, 2007 5:29 pm
oh, in that case
yeah you can do that :twisted:
Postby evil_si » Thu May 03, 2007 6:53 pm
yup sure can,
i have done it plenty of times 8)
all have been legitimate cases thou.
if queried at wof time just say it wasnt compatible with the new running gear and wiring loom.
or the old one fkd out
evil_si
Postby matt dunn » Thu May 03, 2007 7:37 pm
We went thru a similar issue with a BA falcon,
we had a damaged one and a brand new bare shell, and wanted to swap the bits and pieces over and were told no.
We could fit the panels to the damaged shell though.
Ok, so what if we replaced every signel panel in the whole car with the one from the other shell?
Depends on how you word it.
You are not allowed to remove the chassis number and weld it into another car,
But you can remove the entire car from the chassis number and weld a new shell onto the chassis number.......
Dumb rules but it is how it's worded.
In your case you wont have a problem as said before,
evil_si wrote:if queried at wof time just say it wasnt compatible with the new running gear and wiring loom.
and you'll be fine.
Matt
Postby ~SlideWays~ » Fri May 04, 2007 9:52 am
matt dunn wrote:But you can remove the entire car from the chassis number and weld a new shell onto the chassis number.......
Matt
Really?! I thought that was entirely illegal?
~SlideWays~
Postby KiwiMR2 » Fri May 04, 2007 12:07 pm
When your getting your cert they can note the dash as being replaced so when the km's change at wof time your cert explains why :)
KiwiMR2
2003 Estima 3.0L
2000 Opa
KiwiMR2
Postby RunningRich » Fri May 04, 2007 1:41 pm
Just flick the speedo to match?
Richard
http://gtfour.supras.org.nz
RunningRich
Postby Distrb » Fri May 04, 2007 6:36 pm
~SlideWays~ wrote:
2LTR Rona wrote:Have a chat to Distrb though cause he swapped over this in his Tezza :wink: pretty sure he just unbolted & then bolted in
hey fluck you! i can still weld your intercooler inlet pipe arrangement on back to front and upside down :twisted: :P
nah mine was easy enough, just took readings of both speedo's so come warrant time i can work out how many kms are on the car. :lol:
Distrb
Regular Poster
