pedders VS munroe
pedders VS munroe
Postby sponsormycrown » Thu May 03, 2007 4:00 pm
which is better? i only have these 2 choices or stock ones from toyota. as i have a 74 crown and aftermarket bolt ons are not made for my car? any help would be good cheers
how were cars built without the internet in the 90s?
sponsormycrown
Postby RunningRich » Fri May 04, 2007 10:34 am
Performance wise both are crap. Stick to Toyota.
Richard
http://gtfour.supras.org.nz
RunningRich
Postby Dell'Orto » Fri May 04, 2007 11:02 am
Toyota probably dont do shocks for a car that old.
I have monroes in my wagon, just cause I didnt want to fork out the $70 extra for KYB's, and they're alright. Probably only done close to 10,000k's with them now though.
If its a car that you want to handle reasonably well, look toward KYB (effectively the same as TGP ones).
Postby sponsormycrown » Fri May 04, 2007 3:45 pm
yea i rang toyota and they said that they could get it from japan. would kyb make shocks for a 74 crown coupe?
sponsormycrown
Postby sponsormycrown » Fri May 04, 2007 3:46 pm
would kyb make shocks for a crown? how much better are they?
sponsormycrown
Postby 4-AGE 4-LIFE » Mon May 07, 2007 11:46 am
yes kyb make shocks for a crown, only have rears listed, call STOCKS ph 0800 786 257
Ben Threadwell
Exsus Automotive
Suspension specialists
4-AGE 4-LIFE
Postby CaM » Mon May 07, 2007 12:26 pm
early hilux ones, rn40 etc, are the same. I've got them fitted to the front of my ms65. bottom mount is a tiny bit smaller in bolt spacings but i used some hardened washers to make sure they wouldn't pose a problem. works fine.
would want to go for HD oens as I went for the stock replacement and they're a bit soft.... sadly... works for me thought for how I wanted the car to ride like. with stock springs up front they would likely be fine.
CaM
Postby sponsormycrown » Mon May 07, 2007 5:11 pm
rang stocks they said nothing listed at all for a ms75 coupe :( but they did have something listed for a rn40 hilux HD item. $113+GST each. so got the fronts sorted now jus need some decent rears.
sponsormycrown
Postby CaM » Mon May 07, 2007 5:31 pm
mean.
I only stumbled across that as was in the same dilemma as you a wee while ago, and was flicking throuh an AC delco catalogue form the early 80s and saw that they listed them as being the same.
as said, bottom mount needs larger diameter washer but thsat's kosher as IMO.
pedders sports shocks in rear = what I've got. they're firm as $&#$%. Dunno how they'll last htough. doesn't bother me. You;'ll be lucky to find anyhting bar pedders for the rear. Autolign had ONE monroe in stock when I was looking for some. check you've got the tbar style mount at the top of the rear, then ring pedders and see if they can help you out. If you're lowering it, work out the free lentgh you need to
CaM
Postby sponsormycrown » Mon May 07, 2007 6:54 pm
yea pedder had a full set and so did auto align but not a big fan of munroes standard as im doing a transplant as soon as a sort the suspension and brakes with something that is gonna handle and stop well. thanks for the help hopefully get some springs custom made by snell and there telescopic front shocks so they shouldnt need any shortening.
$500 for the front suspension set up!! :( better start saving
sponsormycrown
