diesel injector pump question
Postby groupagt4 » Sat May 05, 2007 12:52 pm
our injector pump is leaking in our mitsi pajero,apparently the new kind of diesel shrinks the o rings.is there any additive i can add to make to o rings swell a bit or replenish it
groupagt4
Postby method » Sat May 05, 2007 1:02 pm
Not that i know of, you have to replace the O-rings to ones that arn't affected by the diesel.
PICS UPDATED DAILY
method
Postby fivebob » Sat May 05, 2007 1:05 pm
http://www.consumer.org.nz/newsitem.asp?docid=2475&category=News&topic=Low-sulphur%20diesel%20causing%20problems wrote:What to do
There are additives that claim to prevent seal leaks. But at best that only postpones the day when the pump will have to be repaired. At worst, if the injection system is not working properly, you'll be creating more air pollution. Additives cannot restore worn parts.
If you get the pump fully serviced now, you should avoid smoke problems later (unless the engine is worn and already burning oil). Getting the injection system to work at its best can improve fuel economy, so you could save money in the long run.
Postby groupagt4 » Sat May 05, 2007 1:06 pm
damn apparently its very expensive mechanic said 800 bucks,do you guys know of any good cheap places in ham
groupagt4
Users browsing this forum: Bing [Bot] and 8 guests
