Petrol station digital tyre inflators - reliable?
Postby Stealer Of Souls » Mon May 07, 2007 5:29 pm
Just wanted to get peoples thoughts on the digital tyre inflators at the good old sevice stations.
How reliable are they?
Accuracy?
Consistency?
'86 AE85.5 Levin
Stealer Of Souls
Postby pc » Mon May 07, 2007 5:45 pm
Pretty good. I always check gas station's pumps with my own tyre guage and the digital ones seem to always be accurate to within 1 or 2 psi.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Ae92typeX » Mon May 07, 2007 7:49 pm
Ideally the should be checked and calabrated, but as above, ive never had an issue with acuracy around my area.
Ae92typeX
Postby Cahuna » Mon May 07, 2007 7:59 pm
Depends when it was calibrated - I set the one at my (then) local Mobil to 33psi when I checked it with my own gauge the tyres were at 40psi. Pumps at other stations matched my gauge pretty closely so this one was just a bad egg.
However, you can't beat a good tyre pressure gauge of your own.
We know that four-wheel drive doesn't work in a racing car, and I proved to myself that it doesn't work very well for rallycross. I'm absolutely convinced that it has no future in rallying, either, even if the regulations allowed it. - Roger Clark (rallying legend), circa 1976
Cahuna
Postby Dragger_Dan » Mon May 07, 2007 9:24 pm
That's if you're lucky enough to find a servo with a working compressor. Went to pump a tyre up the other day, the 5th gas station I went to had one that worked.
Dragger_Dan
Postby no_8wire » Mon May 07, 2007 9:57 pm
Your gas stations have digital meters! 8O
my locals are still the good old mechanical dial type
no_8wire
Postby method » Mon May 07, 2007 10:50 pm
Mobils have digital meters, a monkey could use them. They are pretty shweeeet
PICS UPDATED DAILY
method
Postby Stealer Of Souls » Tue May 08, 2007 9:12 am
Ha ha...
Not the response i was expecting. Bit of a trick question. I just lined up the local BP against my tyre gauge. And I wanted to see other peoples experiences.
I've lined my gauge up against a calibrated pressure gauge and it came out with a +0.5 psi error, but was accurate to 0.1 psi (resolution is only .5 though :( ).
Yeah the local BP was good to within 0.5 psi. And I used one in Taupo which was pretty much spot on!
'86 AE85.5 Levin
Stealer Of Souls
