Exhaust Gasket
Exhaust Gasket
Postby Luke28 » Sat May 12, 2007 7:24 pm
My aftermarket exhaust bolts upto the catty, but where it bolts up, both flanges are flat.. unlike the standard exaust where it has a lip on the flange that the ring gasket slips over. can i get a gasket that will go between the 2 flat flanges? or do i have to change one of the flanges?
Cheers!! -Luke
Luke28
Postby rwd_mayhem » Sat May 12, 2007 7:26 pm
put a bit of paper against it and get an imprint of the shape, then take that into supa cheap/repco etc and they shud be able to give you a flat type gasket to fit.
current: 1975 Valiant Regel
previous: 1980 mazda 626, 4AGE AE70 sedan, AE70 sedan, mk2 escort, KP60 starlet, TE71 liftback X2
rwd_mayhem
Postby Luke28 » Sat May 12, 2007 7:29 pm
ok then sweet. Will it be made from some heat resistant cork or somthing similar??
Luke28
Postby slighty_sykotic » Sat May 12, 2007 8:39 pm
Get a piece of cardboard, and COAT it in maniseal and then just bolt it up tight.
Won't leak.
Or, go buy one. Chances are it will be a metal type gasket.
slighty_sykotic
Postby Luke28 » Sat May 12, 2007 8:51 pm
Ok, The cardboard sounds a bit rangi to me, :lol:
will just buy one, wasnt sure if you could get ones to go between to flat flanges thats all.
Luke28
