How To Bleed Brakes With A.B.S
Postby TOYWGN » Sun May 13, 2007 12:55 pm
Okies anyone know the proper procedure of bleeding brakes with a.b.s ? I know the old school way of doin it as in from the passengers rear then drivers rear then passengers front then drivers front. But not to sure if this is the correct way of doin it on the new school stuff.
Im wanting to do it on my caldina gtt auto if this helps anyone..
Also it has a bleed valve on top of the abs unit too do you need to also bleed that as well?
:D
1997 Jzx100 Tourer v !!!!
TOYWGN
Postby fivebob » Sun May 13, 2007 1:10 pm
Bleed it the way you would do any other car, the ABS makes no difference unless you're starting with a dry system with no fluid.
Postby Redd » Sun May 13, 2007 10:05 pm
wot do you do if you are starting with no fluid and a dry system?
Current Car : 2004 1kz Hilux
Previous Cars : 1978 Ford Escort on 15" reflexes, 1978 Vauxall Chevette powered by a 3K, 1991 ST182 Toyota Celica, 2x SW20 Turbos, 1985 R31 RB20det and an S14 ks
Redd
Postby Zak » Sun May 13, 2007 10:09 pm
Depends on the car, you might have to bleed the ABS unit, some of the new toyota's need the IT Tester just to change the fluid, or do any thing for that matter :?
Best to check your service book, if you can, or just give a dealer a quick call 8)
Zak
Postby Redd » Sun May 13, 2007 10:09 pm
Redd
Postby Redd » Sun May 13, 2007 10:12 pm
cheers man
Redd
Postby skoty » Sun May 13, 2007 10:49 pm
Also had a similar problem attempting to bleed a mates car that had ABS. The normal method didn't seem to work :?
Profile - Cars Owned - AE82 Corolla GT / Corolla Dirt Track Car / N14 Pulsar GTI / S14 Silvia Qs / Nissan Van / Nissan Avenir GT
Current cars - Altezza RS200 and Mitsi Lancer GSR
skoty
