3sgte re-assembly
3sgte re-assembly
Postby ALLTREC_TURB » Tue May 15, 2007 5:41 pm
Ok have startedbolting al the manifolds etc back onto the motor and have just beenout putting the turbo on, but wen i went to fit the down pipe the damn thing doesnt clear the oil cooler etc, anyone have any idea what might be wrong
ALLTREC_TURB
Postby tex » Tue May 15, 2007 11:25 pm
Stupid design of the XSPower dump pipes. You can either loosen off the oil filter or put the dump pipe and manifold on as one piece. I just loosen the bolts on the manifold, slide the dump pipe on before I bolted it up tight.
I am guessing it is an XSpower type dump pipe. Otherwise grind a bit off the stupid thing.
TEX
tex
Postby ALLTREC_TURB » Tue May 15, 2007 11:31 pm
its actually the factory one, the il filter isnt on it at the moment, but i think ill take the turbo off then bolt the down pipe to th turbo and then bolt it back on after stopping nd looking at it again lol
ALLTREC_TURB
Users browsing this forum: Bing [Bot], Google [Bot] and 9 guests
