Cahuna wrote:The 3SGE in the boss's MR2 rally car eats bearings for lunch - he blew 3 motors in 12 months, including last year's Silver Fern Rally. The main culprit seems to be oil starvation but we can't quite get a handle on why; the Silver Fern motor was assembled by Lynn Rogers and was running the recommended Motul synthetic, he runs an Accusump (to boost the oil pressure if it drops for any reason) and an oil cooler directly across one of the vents to the engine bay.
Our thoughts are that the 3SGE doesn't like prolonged high revs - the Silver Fern engine was fine for the first 4 days but lunched itself after around 15km of the first stage of the event with prolonged high-speed and high-revs
MR2SIK wrote:Mine busted at about 165,000km's had a handful of high boost runs during drags etc..
Was driving it rather hard when it did go though..
Mr Revhead wrote:MR2SIK wrote:Mine busted at about 165,000km's had a handful of high boost runs during drags etc..
isnt there a bit more to that story?![]()
the 4age can have a tendancy to run bearingd at high rpm/g loading.
they only hold about 3 litres in the sump.
the 3sge holds a fraction more than that, maybe its the same issue?
not enough oil in the sump for sustained rpm/gs.
from my experience of ppl asking for parts, it would seem lack of maintanece, either lack of oil changing or oil top ups, that is the major cause.
We didn't even open the bottom end leaving it exactly as we got it. Ran it for 4 seasons and over 50 rally events without issue. It even ran upside down a few times.
Admittedly, I'm not the hardest on gear but we did a reasonable amount of winning with it so it wasn't exactly sitting idle.
92mr2paddy wrote:lol, well my gen2 3sge popped bearings at 95kms!! i was sitting at 110km/h then tap.tap.tap, so for what you guys wrote and what ive experienced it might just be a weak design in toyota's 3sge engine???
some get lucky and they last like they should and sum just sh*t themselves for no reason.
haha and no i didnt have 'no' oil in the engine
