mite need to invest in a full face bio mask
are we looking at oil seals and well as rings? wont b 100% sure till we rip it apart, but just so i can get the bits together now. compression pretty much on par
crispy'86 wrote:If you've got the right equipment you can replace the stem seals without removing the head., Just need to put the piston on tdc and get a fitting that screws into your spark plug hole and connect an air line to it, this should keep the cylinder full of air and prevent the valve from dropping into the cylinder when you take the valve srings and collets out,
