****4agze supercharged starlet diff options?****
Postby corolla gt » Sun May 20, 2007 10:03 pm
hi guys i am a bit stumped on a diff for my starlet....you guys are great help ae its helping me heaps with my starlet
i dont want to go 4 hilux diff as my car is low at the back and i will have 2 higher the back to fit diff or it will hit on my floor
thinking maybe a ae85 or 86 diff then shorten?
or a litace diff shortened?
thats all i can think off all i got in it is a 2k toyota starlet diff lol i will blow straight away i would amagine
CURRENT:TOYOTA 1993 Hilux surf
OLD:TOYOTA 1995 HIACE SUPERCUSTOM TOYOTA SPINTER GT 1985,TOYOTA COROLLA GT 1986 (SMALLPORT)
corolla gt
Postby l1ttle_d3vil » Sun May 20, 2007 10:22 pm
ive been running an ae85 diff in my ke35 with a standard bluetop 4age and never had a problem. i don't exactly drop the clutch or do lots of skids though...partly due to only having a non-lsd diff head. they are reasonably cheap, you can pick up diff heads for them for about $50.
thats only ina stock bluetop though, a 4agze will have considerably more power so you'd probably want something stronger...an ae86 diff is stronger, but pretty damn expensive if you break it.
you don't need to shorten an ae86 diff if you run fwd offset mags, same with the older hilux diffs.
Postby corolla gt » Mon May 21, 2007 6:46 pm
so a ae86 diff will fit right in a starlet?
what bout the ae85?
corolla gt
Postby l1ttle_d3vil » Mon May 21, 2007 7:28 pm
ae86 and ae85 diffs are same width, you will need to re do the mounts though - they don't bolt straight in. if you don't shorten them you will need fwd offset mags.
i don't see why so many people want to put an ae86 diff into their 4agte or 4agze cars though. they will blow up eventually from behind a stock 4age, so won't stand a chance behind a 4agte or 4agze. a hilux diff will never blow up and:
the older hilux diiffs don't need shortening ifyou run fwd offset mags, same with ae86 diffs.
you need to change the mounts on both the ae86 or hilux diff, so no advantage there in choosing an ae86 diff.
and you can pick up a hilux diff for around $300, then an LSD head on top of that for around $500.
for a stock, non lsd ae86 diff you'll be looking at around $800, then another $400+ for an LSD ... which you'll probably blow up after a little while.
so for alot cheaper you can get a diff which is a 10x stronger and will give you alot less hassles in the future. as you have said though its because of the size of them, but i would seriously consider going for a hilux diff anyway if I were you.
Postby corolla gt » Mon May 21, 2007 7:55 pm
i mite go for the hilux diff then add me on msn stefegg89@hotmail.com i want to ask you more bout ur diff......so what year is the older hilux diffs then?1989?
corolla gt
Postby sk1dlet » Mon May 21, 2007 8:56 pm
you want to find a early rn41 hilux diff they are about 20mm wider overall
82 4DR KP62 4AGTE MADNESS
98 RS200 ALTEZZA
sk1dlet
Postby Adoom » Mon May 21, 2007 9:50 pm
If you go for the t series diff get a drum brake one from a TE71 celica/supra or a corona. You still have to change the mounts and shorten it by 25mm on both sides. Dont forget to move the spring mounts. They may look close enough but once you get it on the car they make the springs sit UBER wonky.
Discs on the back are really for show on a car so small.
The drums brakes are huge and more than enough braking for a little starlet.
I use one on my racing car(1.8 turbo) and I have had no probs with the rear brakes. I cant say anything about the long term strength of the non-lsd one cause I got a trd lsd for it after a year. Never broke any diff heads, but I dont do many burn outs, tires are too expensive. I like going really fast around corners.
Adoom
Postby strx7 » Mon May 21, 2007 10:08 pm
what ratio are you looking for ideally?
I have an RN41 hilux diff at work, but I also have some narrower diffs that i'm thinking would be suitable, but only come in 4.6, 4.9 and 5.1 ratio's
Postby l1ttle_d3vil » Mon May 21, 2007 10:43 pm
narrower diffs as in what? not hilux?
Postby big_boy » Tue May 22, 2007 12:30 am
another option is some of the auzzy/USA made GA61`s came with a F series rear diff witch is almost a perfect fit for width being F series there reasnably strong & a bit smaller than a hilux G series
for sale EE90
big_boy
Postby corolla gt » Tue May 22, 2007 4:11 pm
what would be a good price for a hliux diff with lsd? do any hilux diff heads fit into any hilux diffs?
corolla gt
Postby big_boy » Tue May 22, 2007 5:34 pm
a good price would be any were from $250-$1000 depending on LSD or not breaks, what the mounts are set up for ect
also all G series are interchangble heads in solid rear axles
for sale EE90
big_boy
Postby sk1dlet » Tue May 22, 2007 9:11 pm
yea mine cost me $450 all up $100 for the diff and $350 for the 4.3 lsd then i sold the 4.8 open for $80
98 RS200 ALTEZZA
sk1dlet
Postby strx7 » Tue May 22, 2007 9:56 pm
l1ttle_d3vil wrote:narrower diffs as in what? not hilux?
Yeah, are any of those ratios suitable or not?
Postby corolla gt » Tue May 22, 2007 10:22 pm
so the ratios how they say 4.3 and 4.5 is it the higher the ratio the more top end speed and the lower the ratio the more low end torque?
corolla gt
Postby big_boy » Tue May 22, 2007 11:40 pm
other way round like i run a 3.7:1 for my supra meaning i have a higher top speed but less torque but you can make up with for that with CC`s
a 4.5:1 will give you more torque than a 4:1 but the motor will rev more at say 100k than a 4:1
for sale EE90
big_boy
Users browsing this forum: No registered users and 22 guests
