high idle causes
high idle causes
Postby bluemaumau » Tue May 22, 2007 7:58 pm
ok i ve replaced alotta crap on my gze but want to make sure its completely mint idle!
so if anyone could list anything, absolutely anything that would cause high idle it would be appreciated.
so far ive got:
*incorrect ignition timing
*incorrect cam timing
*air leak (gaskets/hoses)
*incorrect TPS
*incorrect ISC
*idle screw
*faulty AFM
*faulty ECU
*bad earth
*valve clearances out
*throttle cable sticking
everything above has beeen checked/or replaced.
so im looking for anything else?
can dodgy wiring contribute>? :?:
if you have any more, post em up and ill add them to the list
please help
Postby EVL20V » Tue May 22, 2007 8:10 pm
the maD LumPy Rota STYleZ caMs au :lol:
throttle cable adjustment?
EVL20V
Postby bluemaumau » Tue May 22, 2007 8:11 pm
yea its not even hooked up, but ill add it
its got bluetop cams, so im expecting a higher idle, but not 800rpm higher!
Postby EVL20V » Tue May 22, 2007 8:34 pm
idle control valve? if applicable?
EVL20V
Postby pjay » Tue May 22, 2007 8:39 pm
the gze's all have odd idles. its something toyota never ever fixed. I idle anywhere between 1-2.5 depending on how my gtz feels i guess. if you find a solution id love to hear it!
pjay
Postby DocT » Tue May 22, 2007 8:45 pm
Dirty injectors, leaking thermostat
DocT
Postby 85AW20v » Tue May 22, 2007 9:07 pm
Blocked coolant hoses to the throttle body along with the waxstat thingy being sticky - if it's got one. Take the throttle body off and give it all a good soak and clean, then make sure there's coolant flowing nicely through the lines when you put it back on.
See ya
Simon
85 MR2 20v
85AW20v
Postby 85AW20v » Tue May 22, 2007 9:08 pm
Double post...
See ya
Simon
85 MR2 20v
85AW20v
Postby bluemaumau » Tue May 22, 2007 9:46 pm
hmm can dirty injectors actually be a cause. ?
i have cleaned the throttle body as best i can
cheers everyone, keep em coming! :)
Postby Stealer Of Souls » Tue May 22, 2007 10:07 pm
Eliminate the idle control valve by blocking all the holes with your fingers...
Stuffed/dodgy valve = fingers work a treat. Answer is then take the valve off and replace it with a plate.
Fingers do nothing (or very little) = something VERY wierd...
'86 AE85.5 Levin
Stealer Of Souls
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
