Pod filter explosion
Postby toyrota mota » Mon May 28, 2007 2:46 pm
So I got bored and decided to put this pod filter we had lying around on my mr2(4age). And from alot of photos id seen people put the pod filter straight on the tb. Yer yer i know this isnt the best way. But the standard filter was dirty as $&#$% and i needed to clean the tb anyway. And i just wanted to see how it went. So i cleaned and oiled the pod with sum k&n stuff and bolted it on. Went for a drive all was fine, no real gain as i imagined.
However I go to start it up today, it turns over once and theres abit of a bang and alot of white smoke starts coming out the engine vents. It appears that the engine flamed out the tb, like backfired up the intake. Because the pod filters all burnt and melted inside. Wtf? Why did this happen? The only reason i can see that would cause this, is the k&n oil dripping off the pod filter and down the intake into the engine.
P.s. sorry about asking a pod filter question, but it exploded! Proably serves me right for putting a pod on haha
toyrota mota
Postby barryogen » Mon May 28, 2007 4:12 pm
sounds like you over oiled it, and indde3d the oil went down the intake, and flamed out when you turned it over... would be cool to have a video of it, but probably not particularly good for the engine.
barryogen
2ZZ Guru in training
Postby Mr Revhead » Mon May 28, 2007 4:38 pm
exploding pod filters.
what ever next :lol:
first thing id do, is pour some of that oil on the ground and set fire to it.
see if it burns.....
have you tried running the car since?
Postby Defective » Mon May 28, 2007 5:08 pm
Mr Revhead wrote:exploding pod filters.
haha, i was thinking when i first read this that i didnt think filter oil was flammable...... 8O
Defective
Postby Mr Revhead » Mon May 28, 2007 5:24 pm
thats why i asked him to burn some. to see if it burns!
if not... add petrol :twisted:
Postby Ae92typeX » Mon May 28, 2007 5:42 pm
lol, I have never heard of that happening. Spraying carb/throttle cleaner into the throttle with the engine running has never caused a flame to blowback in my experience, so I would think even less chance with the oil - assuming cam timing etc is all correct.
however, the oil itself is flamable & has a warning on the pack. I just sprayed a puddle of it on the bench and set fire to test. :twisted: flame :twisted:
Ae92typeX
Postby Mr Revhead » Mon May 28, 2007 5:50 pm
good man :D
so have you fiddled with anything else? (on the car....)
Postby toyrota mota » Mon May 28, 2007 7:33 pm
Yer theres three pictures on the front of the bottle of k&n filter oil, 1 of skull and cross bones(poison) 1 of flames(flameable) and 1 that looks like an explosion(explosive?) haha. Didnt think they'd make filter oil so flameable!
Yer i put all the stock air intake back on it ran fine. Only other thing i had done was use sum tb cleaner before putting the pod on. Oh and i had put sum of that morey's injector clean in the tank.
It was pretty warm 2day when i started the car and it had been sitting in the sun all morning. Maybe the filter oil evapourated and stayed inside the filter/intake manifold. How would it ingnite in a cold engine tho? When the spark plug fires the valves whud b closed. And how come it didnt do this the 1st time i drove it?
toyrota mota
Postby Mr Revhead » Mon May 28, 2007 7:46 pm
its possible that fumes were ignited by a spark, not nessicarily from the plugs them selves....
how much oil did you put on it? and how much cleaner? was there any still floating around?
begining yo sound like there was some fumes still there
Postby toyrota mota » Mon May 28, 2007 7:54 pm
Mr Revhead wrote:its possible that fumes were ignited by a spark, not nessicarily from the plugs them selves....
I put a bit of oil on it but it was dripping or anything. Cleaner? Couldnt have been the throttle cleaner.
I cleaned the throttle, cleaned and oiled the pod and then put the pod on on saturday. Then took it for abit of a drive and everthing was fine. Now on monday after not starting it since, i start it up and this happens.
This is werid!
It wasnt a k&n filter just one of those el cheapo 1s I think.
toyrota mota
Postby Defective » Mon May 28, 2007 7:58 pm
i suppose it makes sense that filter oil is flammable, after all, you wouldnt want anything that wouldnt go bang getting sucked through with your fuel/air mix.... (like a water-based additive 8O )
hmm, i can see a money making thing here.... anyone wanna buy some genuine hi-octane racing filter oil? :P
Defective
Postby sergei » Mon May 28, 2007 9:11 pm
Defective wrote:i suppose it makes sense that filter oil is flammable, after all, you wouldnt want anything that wouldnt go bang getting sucked through with your fuel/air mix.... (like a water-based additive 8O )
what is wrong with non flammable stuff in the engine? Heard of water injection? What about air being ~70% non flammable?
Postby Defective » Tue May 29, 2007 7:10 am
sergei wrote:[
i was more thinking along the lines of thick goopy oil that wouldnt go bang...., rather than something like a water injection set up..... :P which is set up to atomise nicely....
Defective
Postby toyrota mota » Tue May 29, 2007 5:34 pm
I guess if the filter oil was waterbased itlld jst evapourate
toyrota mota
Postby mr30%jr » Tue May 29, 2007 6:05 pm
bearing in mind the cold start injector is way up in the plenum it would have made a lovely oily petrol mix
mr30%jr
Postby toyrota mota » Wed May 30, 2007 5:25 pm
I still dont get it tho. Theres no way the oil could have dripped into the intake, it would only drip off the pod.
toyrota mota
Postby SUBARUCONVERT » Wed May 30, 2007 6:49 pm
intake backfires are pretty normal if u are spraying or have alot of very flamible crap in there, one the GDI's at work we soak the intake manifold in throttle body cleaner then start them, can get sone crazy intake explosions, one blew the honey combe in the AFM to bits. usually the ecu gets the timing alittle wrong sometimes when u crank
3ST150
SUBARUCONVERT
