30 minutes later the car could start from the key no problem.
now im thinking its either the brushes in my starter are stuffed or ive got a dodgy connection in the starter circuit. ive got a couple of ideas where that could be but before I go pulling all my wiring apart, if it WAS the brushes in the starter motor that are stuffed would it atleast "click" when I turned the key to start?
hope this makes sense. im getting kinda desperate as I need to fill up with fuel and methinks it'd be a bit dodgy shorting the starter out at a fuel station...with sparks flying...
thanks
